Question about Toshiba 27DF46 27" TV
Lost sound on Toshiba 27DF46
We use this TV just a few weeks a year.  It played both DVD's and Video with sound.  Then I must have hit the wrong button or something, and now there is no sound.  And no, it is not on mute!  It is using the ColorStream and Dolby settings right now for videos.
I went through all the settings listed in the users manual to no avail  Thanks,  VT
  • drohnerd Apr 10, 2009
    Distorted sound on only one station, All other TV's in home receive station without distortion
  • May 11, 2010
    Have you tried the set on regular TV to see if it has sound there? Is there a rear-panel speaker switch that may have gotten bumped to OFF? Have you tried turning off Dolby and using only the most basic stereo sound setting as a test?
    Sergeant:
    Champion:
  • 346 Answers
Check to see if there is speaker switch at back of tv
Posted on May 21, 2010
Well, I solved the problem.  First of all, I should have left it on "ant" and left the Television to figure out whether there was a DVD in it or not.  Then, I had the wrong channel which was just plain stupid.  But the weirdest thing is that my remotes are not working and they were fine.  I changed the batteries and no luck, so I will have to see what is what with that.  Fortunately, even though they won't turn things on, they will work the volume.  I have a feeling our new wireless system is having some kind of effect on them.  Great.
Posted on Feb 08, 2009
Toshiba 27DF46 27" TV started only turning on
Bad solder connections on an older TV is common. Check all your solder grounds on anything mounted on heatsinks. The other thing is bad capacitors. Always suspect the 160 volt to 250 volt at 1 MF, 2.2Mf or 4.7Mf for being bad. This is true for many repairs for any brand of TV.
Dec 15, 2010 | Toshiba 27DF46 27" TV
Sound no picture with dvd player
Exchanged AmEx Rewards points for 3 Toshiba Model DS-4000KU DVD players in 2007. All stopped working. Two a year ago, one this week. Errors - can't read disc, bad disc, etc.
Warranty period is up. So I decided to open one up tonight since they were going in the garbage anyway.
Put on rubber gloves and took off the case. Unscrewed the player unit, lifted it carefully, and untaped lines from the botton of the unit.
Plugged the unit in and powered it on. Did not blow up! :>)
Jiggled some of the lines and connections. Put a disc in and it read it!
Attached it to the tv without putting the case back on. Received video. Yay! But no sound. Boo!
Jiggled the lines some more and tried it again. Working fine now.
Will put the case back on later and see if it still works.
Dec 09, 2009 | Toshiba SD-4000
DVD only plays in black and white on my Toshiba 27D46 TV
Check on the dvd menu for the video format maybe that´s the problem
May 16, 2009 | Toshiba 27D46 27" TV
Toshiba 62hmx84
Does your Tv have Input on the remote? if so maybe she hit the input button by mistake. The newer tvs have a few different inputs into them. Like HDMI or regular cable or vcr or dvd. i would try that to see if that helps. Hope you get it figured out.
Jun 27, 2017 | Toshiba 62HMX84 62" Rear Projection HDTV
Connecting VCR to TV
If you have the original remote controller, try to switch inputs. It must be on the f-connection ( coaxial) at the moment. You need to switch it to RCA or S-Video Inputs.
Aug 30, 2008 | Toshiba 27DF46 27" TV
Toshiba 27df46
i have the exact same problem. i used to be able to turn it on and off but that does not work any more. hope someone has an answer for this.
Aug 18, 2008 | Toshiba 27DF46 27" TV
I get no picture on TV
Dear friends,
Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
Oct 31, 2007 | Cyberhome CH-DVD 300 DVD Player
No sound
If the tv does not have sound with out connecting the dvd then you are having a problem in your audio circuit have a tech look at it.if its only when you connect the dvd then you could have connect cables wrong.you cannot route a dvd through a cable box.any dvd s compatible with tv so long as the connections are there. goodluck.
Dec 28, 2006 | Toshiba 32HF73 32" TV
Toshiba 27DF46 27" TV Logo
127 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
