Question about Singer 132QRFB Mechanical Sewing Machine
Singer Athena automatic needle threader does not work.
Does anyone have experience with the Athena 2000 needle threader? It seems like the thread fall just a hair off the mark, but I can not even determine how it is supposed to work in order to try to fix it.
    New Friend:
Singer 5400 Needle threader will not engage. It is jammed.
Posted on Jan 17, 2014
    Scholar:
  • 69 Answers
Check on the threader and see if the part that goes through the eye of the needle is bent. This is a very common problem. The threaders are becoming more and more difficult to replace. If the piece is bent, you can usually use a pair of tweezers to straighten it out.
Posted on Feb 09, 2009
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
There's nothing wrong with the Threader, it's just that the Threader doesn't reach the back of the Needle!
Usually you have to manually move the needle up and down until its height matches the threader height. Newer machines have an automatic needle stop that generally matches the threader but most older machines need to be manually manipulated.
HINT: If you do need to manually thread your needle, lick your index finger and then rub the back of the needle's eye. Your thread will literally "leap" through the eye! This works for hand-sewing needles too!
Feb 03, 2016 | Singer 8763 Curvy
I cannot get the CE-250 automatic needle threader to work. Threader and needle do not align up together.
Always make sure you rotate flywheel to raise the needle to its highest position before trying to use the threader. additionally the correct needle has to also be used so the threader wire and needle eye line up properly.
Cheers,
Embroidery Services
San Diego, CA
Sep 17, 2017 | Singer Sewing Machines
Fix thread cutter on singer quantum xl 100
Is it blunt? Is it angled properly . these and needle threaders are a pain in the neck, I just use scissors and thread my own needles.
Best wishes
Jan 24, 2015 | Singer Sewing Machines
The self threader won't catch the thread
make sure the needle is inserted correctly into the needle holder
if the needle threader has worked before then there could be something
wrong with the needle threader
here is a link for a manual
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Dec 13, 2012 | SINGER 7470 Sewing Machine
I changed my needle on my singer 3116 and the needle threader does not work anymore. Hope you have an answer! Thanks!
It is probably out of alignment, just turn your needle threader so that the little wire goes through the eye of the needle and will catch thread. Also, sometimes the needle you put in has too small of a hole to thread easily with the automatic needle threader.
Oct 01, 2010 | Sewing Machines
Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
Apr 11, 2009 | Singer Sewing Machines
Automatic needle threader on brother se-350
Hi - first, make sure that you raise the needle to as far up as it will go. When you thread the machine, make sure you pass the thread through each number along the path - there is a hook on the threader mechanism that is really easy to miss. It is always a good idea to refer to the book when you are having a problem.
You might also try changing the needle. The threader has a teeny hook that goes in to the eye of the needle from behind, grabs the thread, and pulls it back thru the eye of the needle.
The threader can go out of alignment. If you got the machine last fall, it should still be under warranty. You can call Brother and ask where you can take the machine for repair. Or, you can go to Brother's website and look for information that might be helpful.
Good luck,
Ginny
Dec 21, 2008 | Brother XL-3500
Singer 132QRFB Mechanical Sewing Machine Logo
756 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
