Question about Gorenje K337MLB Bottom Freezer Refrigerator
Gorenje K337/2CELB I bouch this freezer (model K337/2CELB) in 2004, have a following broblem - time to time the error E2 occurs for the freezer chamber, but the temperature is in normal range. Please, explaine- what is this, and what has to be repaired.
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: I have a problem with
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Posted on Jul 30, 2011
SOURCE: Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Posted on Oct 09, 2011
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
E2 error code aw-8990st toshiba wash
Toshiba top load washers have standard error codes. Depending on the display (2 or 3 digits depending on the model) it will either show E21 (or E23) or alternate E2 and -1 (or E2 and -3). Here's a list of most Toshiba washers error codes;
E1: Water doesn't drain in time or not at all
E21: Lid open
E23: Lid not locking
E31: Load imbalance
E32: Check E1 and/or E31
E5: No water coming in
You can try resetting to factory default by following the procedure: Power OFF, then pressing and holding the Super Spin Dry button, press power ON and it should beep 3 times.
Hope this helps
Jan 25, 2014 | Washing Machines
My washing machine toshiba aw-9760s Kept showing this "E2 -3" problem. Whenever i close the lid to start washing my cloths. Anyone here can help me? In need of answers A.S.A.P
I also have a Toshiba AW-9790S, and encountered similar problem. The E2-3 would occur sporadically and halt the washing programme. E2-3 error occurs when the washing machine detects that the lid is not properly seated and locked during the rinse or spin cycles. I took mine apart and resolved my problem by cleaning the contacts for the switches. There are 2 contact switches at the lower right side; 1 for sensing the lid is closed and 1 for sensing that the lid lock is engaged. Both the switches were slightly oxidized which prevented current flow and the sensors from working properly.
Nov 02, 2013 | Washing Machines
An error occured we cannot print a document which the orange light was blink semoustanousely
Damage canon printers, can be identified from the number of lights blinking in orange. So, you calculate, how many times the orange light is blinking. Example E2, E3, E4, E5, E8, E9, E13, E14, E15, etc.
Problem
For
the error code E13 = The following ink may have run out black/color
Solution
Press and hold the Reset button about 10 second. E13 error on canon pixma, occurs twice. E13 for black cartridges, and E13 for the color cartridges
Nov 25, 2011 | Canon Pixma iP2700 InkJet Photo Printer
I have a problem with Gorenje HZOS3366 Bottom Freezer Refrigerator. A temperature indicator shows e2 error and -12 temperature.
Leo Ponder
imufo2
Jul 30, 2011 | Gorenje K337MLB Bottom Freezer...
E2 intermitent
E2 error code means the evaporator sensor is fault.
This needs to be checked against a temp/resistance chart which may require the PCB to be replaced.Only service professional can test it.You need the device for testing it.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 18, 2010 | Gorenje K357 / 2 Bottom Freezer...
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
E2 fault on Bosch kgu3201
Dear Sir,
It's a thermistor error, the internal evaporator one... but disconnect the fridge and freezer ones first in turn to see if the error changes. If it is the internal one, you should see an arrow impression on the paper covering the insulation which marks the spot to dig(at the back of the freezer.) Usually this error occur when water ingresses the push on tags, shorting out the thermistor.
Now the bonus... 9 times out of 10, you don't need to buy a spare, as there will probably be nothing wrong with the error giving thermistor. Remove and fit the fridge thermistor in the place of the internal one... clean and dry the internal one you removed and refit it inside the fridge.
You will need to repair the insulation with two pack brown foam insulation and foil tape. deffinately this solution solves your problem.If you have any problem regarding this issue post comment more information about the problem.we will glad to assist you
good luck.
good luck
Aug 26, 2009 | Bosch Refrigerators
Gorenje KE267MLA Fridge too warm
higher the number, colder the fridge ie 7 is the coldest setting
switch with red dot is for summer/winter operation. only necessary to switch it on if the appliance is in a cold location
Sep 30, 2008 | Gorenje Refrigerators
Error code E2 (with a picture of a wrench)
E2 means a problem with the fill. The wrench means to contact Hobart for service
Feb 27, 2008 | Hobart 29 in. AM15-1 Free-Standing...
Gorenje K337MLB Bottom Freezer Refrigerator Logo
264 people viewed this question
Top Gorenje Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
Are you a Gorenje Refrigerator Expert? Answer questions, earn points and help others
