Question about HP Computers & Internet
Cannot connect to a dlink router using a atheros ar 5005 card
I have a dell laptop that connects fine, it is running vista. My new laptop is running vista prem.
  • 1 more comment
  • dlhov Feb 08, 2009
    This did not help. The atheros wireless does not see the dlink router. Thanks for the help
    A icon for what,
    It saying currently connected to the network, accedss local and internet. I am hard wired right now to get on the internet.
    Genius:
  • HP Master
  • 1,102 Answers
MAKE SURE YOUR DRIVER SHOWS IN DEVICE MANAGER
IF IT HAS A ? OR ! THEN CLICK AND REINSTALL
IF THAT DOES'NT HELP --------- THEN GO TO
CONTROL PANEL THEN NETWORK CONNECTIONS
IF YOU SEE YOUR CONNECTION RIGHT CLICK AND IF OPTION TO ENABLE THEN CLICK TO ENABLE
IF NOT CLICK REPAIR.
IF THIS DOES'NT HELP PLEASE LET ME KNOW AND DON'T FORGET TO RATE ME
Posted on Feb 08, 2009
  • 4 more comments
  • DEKR
    DEKR Feb 08, 2009
    do you have a icon in the taskbar
  • DEKR
    DEKR Feb 08, 2009
    when did the problem start
  • DEKR
    DEKR Feb 08, 2009
    for wireless in the taskbar
    and if your gettining error message what does it say
  • DEKR
    DEKR Feb 08, 2009
    okay
    remove from direct
    then open network connections in control panel
    see if the wireless is showing
    if so then highlight it
    then on left side of page you'll see view wireless connections
    highlight on left side click to refresh you may need to do this a few times
    if a connection comes up highlight and click connect
    let me know
  • DEKR
    DEKR Feb 08, 2009
    sorry for got to tell you to after unplugging wired connection also click it in network connections and at left side of page disable it while your tryin to get wireless
    you can always enable later
  • DEKR
    DEKR Feb 08, 2009
    have you been able to get on wireless yet
    also check your laptop for a wireless switch usually at the top of keyboard or on the front of laptop be sure its on
Cannot connect my Dell Inspiron 1012 to my wireless router
what model of DLink do you have and what operating system are you using?
I have a sample of a router set up in my tips and tricks I think youll find very helpful,
http://www.fixya.com/support/r4582466-set_up_speed_touch_5x6v6_broadband_modem
or
try download the info you need from
www.dlink.co.nz
www.dlink.com
its not going to be to hard to fix,
have you tried running a network wizard setup yet?
Hope this helps,MISTERDJ
May 27, 2010 | Dell Inspiron 5100 Wireless Mini-pci...
Can not connect to the internet using my DLink 514 wireles router
May be the wifi modem drivier is not installed properly. check it using device management
Apr 19, 2010 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
How do I intall the dlink router if I dont have a cd drive My computer is a dell inspirion and is runs on vista
hello, here is what you need to do: if have a pc connected to high speed modem directly you will unplug the network cable from the back of your pc/laptop and that end will then go in to "WAN" port on the new dlink router.
second, you take another wire and plug one end in your pc/laptop and the other end in one of the 4 lan ports in the back of your new dlink.
restart everything in the following order at 30 seconds duration:- first the cable/DSl modem, then dlink, then your pc/laptop.
once everything is up open up internet browser and test connectivity.
at this point you should have internet up and running but you need to configure you router and wireless etc.
from your browser in address bar type in http://192.168.0.1 and hit enter that will bring you router login prompt : default user name is "admin" and password is left blank and hit enter, you are now in router to configure options as you please.
I would strongly recommend changing your router password administration and if you plan on using wireless, setup SSID, encryption, network key on wireless. NEVER LEAVE IT OPEN.
Hope this helps
let me know if you have any questions
Amar Sondhi
Dec 04, 2009 | D-Link / RangeBooster N 650 / DIR-635 /...
Cannot connect via wireless to dlink 655. wired connection works fine. when i disconnect to go wireless the laptop sees the dlink but there is no internet connection. running Vista Home Premium. static...
You must manually configure the wireless settings. Go to Network and Sharing Center > Manage Wireless Networks. Remove all the listed network there. Then click Add > Add Network in Range > Select your signal > Type the security if you have and press connect. That should do it.
Sep 23, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
I am unable to connect to the internet with my dlink
Just connect my dlink 615 to a new dell computer on the vista page for the Network and internet the broadband connection is disconnected. What can I do to connect it? When I switch the dlink network back to the old computer everything works fine.
Aug 03, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Cannot connect to DLink DIR-655
The part below is all you need to look at, the rest is Ethernet which is your wired connection, ethernet card.
Here is what are causing your problems from what you gave me and basically your computer is not communicating with the router:
1)I don't see any IP address for your laptop so you can't get on the internet if you don't have an IP address, also, I don't see any gateway address. The gateway address is your router address, and that address is given to the router automatically from your Internet Service Provider.
So if your computer cannot see the gateway address then the gateway address (router) cannot give you an IP address to get on the Internet.
Your Wireless card looks ok, that is the physical address and if you were able to do the loopback then its working.
So on your laptop I would begin from the beginning. Go into network connections and delete the DLink connection if it is there. Then Start>control panel>Network connections>click wireless network connection>click change settings of the connection on the left window>click wireless network tab>make sure checkmark"use windows to configure my wireless network settings>click add a new network>TYPE IN THE SSID FOR THE NETWORK>ENTER WEP/WPA KEY>CLICK OK, then close and you should be connected.
You said other computers are able to access the internet thru the DLINK so it all points to your laptop not being configured correctly.
HOWEVER :)...I see alot of "Media disconnected in your list. Make sure all of the lights are working on the front of the router, if not check the cabling or call the ISP sometimes the problem is on their end. Hope this helps, keep me updated.
C:>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : HPdv7
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Atheros AR5009 802.11a/g/n WiFi Adapter
Physical Address. . . . . . . . . : 00-24-2B-12-FD-63
DHCP Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
May 01, 2009 | D-Link Xtreme N DIR-655 Wireless Router
My asus laptop pro3 series version F3JC will not connect to or locate wireless network at home which uses d-link wireless router. laptop is running vista premium. it will connect if i use a wireless usb...
I have seen issues like this before , certain chipsets/drivers of wireless cards and routers just dont like each other.
We know your wireless card works just as we know your router works. Trick is to get them to play nice together. Unfortunately, there is no quick and easy way to do this, you will have to try different driver and firmware combos until you find one that works.
You can get dlink updates here
http://support.dlink.com/downloads/
And you can try these drivers here.
http://asus-drivers.blogspot.com/2009/01/asus-f3-f3jc-driver-download.html
One other thing you can try before messing around with drivers and firmware is changing the application you use for wireless. The default for your setup is probably Intel Proset. Try using the native Vista wireless manager and see if that does anything. to access that go to start , run , type in services.msc, scroll down to WLAN auto config. Double click on it and then click on start. If you still cant see your router, its time to start trying drivers and firmware.
Apr 07, 2009 | ASUS Air Notebook
Cannot connect to the internet
open internet explorer, go to tools, internet options, then the connections tab and make sure ' never dial a connection' is ticked, assuming you had a dial up connection before using the router on this pc or if you briefly used it.
Aug 18, 2008 | Dell Wireless 2350 Router
Computers & Internet Logo
75 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
