Question about Epson Stylus CX9400 Photo Printer
HOW DO I CHANGE THE INK CARTRIDGE IN THE EPSON CX9400
WHEN I OPEN THE MACHINE THE INK CARTRIDGES DO NOT MOVE OVER SO I CAN CHANGE IT
    President:
  • 2,692 Answers
CX9400Fax, All in one?  If so; download the manual and/or Q& A and /or trouble shooting guide for instructions:
Link
Posted on Feb 07, 2009
HOW CAN I CHANGE A INK CARTRIDGE IN MY EPSON DX7400 THAT IS NOT EMPTY
Connect the power cord, rise the cover that accesses to the print-carriage, turn On the printer; when the print-carriage move to left, unplug the power cord then, manually, move the carriage until the right area where you can open the cartridges-cover and change the cartridge you need.
May 21, 2010 | Epson Office Equipment & Supplies
I would like to refill Epson Stylus CX9400 old ink
You cant recode the cartridge it is programmed to die and fry. You can get chips but many DIY filling options are going to cause you other issues down the road, they are a cheap way to run your printer but eventually willc ause you issues such as ink leaks which leads to the in pad needing to be renewed not to mention some other horror stories. I would alays reccomend OEM inks, but if non OEM is hte way you want to go contact a retail outlet that specialises in refilling spent cartridges.
May 11, 2010 | Epson Stylus CX9400 Photo Printer
Just purchase and set up Epson Stylus CX9400 Fax Series. States "Cannot recognize ink cartridges." It also has a RED box with a Y and a YELLOW box with a Y both have same number (69) next to them Removed...
Make sure cartridges are part number 69 on all four or 68 on the black if its the high cap cart.
Also check the carts contacts and the machines contacts in the cartridge recetacle for contamination or damage.
Apr 27, 2010 | Epson Stylus CX9400 Photo Printer
I wouldn't recommend it because it will void your Epson warranty.
Color Ink prints are nice, but this cannot be an everyday printer --- the cartridges will put you in the poor house.
Buy a cheap monochrome laser printer (recommend the Brother brand) and save the purple ink for the elections.
Cheers!
Mar 19, 2010 | Epson Stylus CX9400 Photo Printer
Broke and can't buy new color cartridge can I print in black only
No, the printer will not work with missing or empty cartridges.
Jan 07, 2010 | Epson Stylus CX9400 Photo Printer
How to change the ink of an epson stylus sx215
press the index sheet button and the scan button at the same time, you then get setup menu. use" >" to select "change ink cartidge". the ink cartidge will move to the opening position. lift the grey plastic clip at the back, and it will open towards you. then they just pull out
Jan 07, 2010 | Epson Stylus Multifunction Inkjet Printer/...
REPLACED TWO 68 CARTRIDGES IN CX9400 EPSON
Generic carts are sometimes not recognized. Epson's chips are the cause. I solved this problem for a small investment. I purchased a CISS system for about $75.00 [ink included], that's the cost of OEM carts that do not last very long. The CX9400Fax is an Ink Hog, which is why the printer is so cheap. If you want a CISS go to http://www.inkproducts.com/ink-store/ They are great if you need help and will call you back in less than an hour. Get the Waste Ink Kit when ordering the CISS.
Apr 05, 2009 | Epson Stylus CX9400 Photo Printer
Change ink cartridge on epson stylus SX200 -printing head moves from side to side but then parks to the R and I cannot get access to change the cartridges.........
The ink cartridges are all separate so you press the cancel button (with no jobs pending) to bring the cartridge holder in to the right place open the holder remove the cartridge and then replace it, let the printer purge the cartridge then your good to go
Mar 24, 2009 | Epson Stylus Photo R320 InkJet Printer
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
New out of box!!
If you already have tried reseating all of the inks and and inks are still not recognized, Please contact Epson tech support for a replacement ink or if they find out after some diagnostics that it is the printer that is having an issue they would be replacing your printer.
Jun 22, 2008 | Epson Stylus CX9400 Photo Printer
Epson Stylus CX9400 Photo Printer Logo
585 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
