Question about Boss Micro BR Digital Recorder
BR-1180 won't power-up
Not sure if I have some sort of "short" or what. You press the "power" button to turn the unit on, then there's a quick flash of light on the LCD (like it is about to turn on), but it then won't turn on. Nothing. Any ideas? Trying to avoid a $200 plus servicing/repair. And still prefer my 1180 over computer programs.
Much thanks, portlandsongwriter
    New Friend:
Any1 have solution to this? tried the above but still won't work. seems to have little to do with hard drive?
Posted on Aug 12, 2015
  • 716 Answers
I Own This Unit And I Tell You What I Love It And Cant See Myself Using A Computer Anytime Soon. You Can Open It Up And Check For Loose Connections By Removing The Screws Shown Here
Youll Wanna Remove The Disk Drive Cover First Indicated By The Blue Dots. Once Inside There Arent Many Connections To Check But Now You Can Unplug The Hard Drive And Try Powering The Unit On Again. See If You Get The Same Result. Once Thats Done Plug The Hard Drive Back In And Try Again To See If It Works.
If It Doesn't Call Roland Theyre Costumer Support Is Awesome And They Can At least Give You An Idea Of What May Be Wrong.
Roland Corporation U.S.
5100 S. Eastern Ave.
Los Angeles, CA 90040-2938
323-890-3700
Also Very Helpful Is This Guide On How To Remove The Hard Drive And Replace It Found Here.
I Hope Some Of This Helps.
Posted on Feb 18, 2009
I cannot turn on my Micro BR - its plugged in and has new batteries but still won't work Does this mean it's completely broken or is there some sort of stand by phase that may have initiated itself?
The devices that have battery AND adapter capability OFTEN have a switch that the adapter opens when powered by the adapter. Often this switch contact gets bent and units won
t run on battery, so try it on an adapter... if the adapter works and battery doesn't, this contact whcih is a part of the input power connector has failed.
Sep 06, 2010 | Boss Micro BR Digital Recorder
I am getting "CD Write Error" on my BR-1180 when attempting to burn a track. It is sporadic; sometimes I get a burn, but lately it has increased and I have now gone through 15 cd's and getting this...
MICHAEL SCOTT: YOU PASSED ALONG SOME GREAT INFORMATION BUT IT ONLY GETS ME HALFWAY THERE...
I HAVE ALL THE NECESSARY CABLES HOOKED UP. DO YOU HAVE TO RECORD MY SONG FROM THE 1180 TO AUDACITY OR WHAT?...THIS IS ALL NEW TO ME AND IT MAY WORK BUT TELL ME HOW TO RECORD FROM THE 1180 TO AUDACITY.
THANKS...GEORGE SLADEK
Aug 18, 2010 | Boss Micro BR Digital Recorder
BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
May 23, 2010 | Boss Micro BR Digital Recorder
BR-1180 Cd will not burn CD's does it call for
Don't know if this unit is sensitive to the type of CD, but my Phillips recorders will ONLY burn the "Music CD's" (harder to find, more expensive). Read up on the difference of regular vs Music CD's. ALSO some recorders will not burn disks rated at lower or higher rates.
Oct 10, 2009 | Boss Micro BR Digital Recorder
What do I need to burn a cd from my pc with the br 1180
This Is real simple grab a cable that goes from rca jacks to a headphone jack then plug the rca jacks into the br-1180's audio out jack and then plug the other end into your computers mic port.
Download Audacity From www.Audacity.com and then use it to capture you audio and then you can burn that when complete.
Its real simple I do it all the time even though I have the br-1180cd the cd burner burns real quiet so I don't use it. The cable can be bought at radio shack, best buy, wal-mart and I have even seen them at 99 cent only stores.
If you have more question let me know This Is my main unit so I know a lot about it.
Sincerely,
Michael Scott
Apr 29, 2009 | Boss Micro BR Digital Recorder
No CD writer for Boss BR-1180
Hey mike yeah you can hook a regular cdr drive to the ribbon but the problem is if its not a slim it most likely wont fit inside the unit. Also the built in c.d r is way over rated mine has it and I still bounce it all onto my computer and then burn it from there. The one on the br-1180cd burns very quiet.
Apr 23, 2009 | Boss Micro BR Digital Recorder
BR8 Digital recording studio lights up, but it doesn't do anything else
I called Roland at the number that you provided and gave they following proceedure which will re-intialize the BR 1180 and ERASE everything that was created on the HD:
  1. Simultaneously hold down button beneath volume control at track 5 and Undo/Redo button at upper right
  2. Press power button while holding down buttons as above, until test menu comes up
  3. Turn selector dial untill initialize screen shows
  4. Prdess ENTER and initialization will start
  5. Once initialization is completed, power off unit and then power it back-up.
NOTE: This proceedure erases all data!
Apr 16, 2009 | Boss Micro BR Digital Recorder
Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
I can record anything to a cd with my boss 1180 br it always say
Im Guessing Your Trying To Burn It Off Before Mastering It Which Means All The Tracks Between 1 And 10. First You Click Audio Cd Write/Play Then Select Disc At Once And Then It Should Guide You From There. I Hope This Helps
www.Myspace.com/CrossRoadsToNowhere2007
Dec 24, 2008 | Boss Micro BR Digital Recorder
MY Boss br 1180 ,disk error
before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
Dec 06, 2008 | Boss Micro BR Digital Recorder
Boss Micro BR Digital Recorder Logo
437 people viewed this question
Top Boss Music Experts
Michial Gueffroy
Vito Vacirca Jr.
shaun taylor
Are you a Boss Music Expert? Answer questions, earn points and help others
