Question about 2wire HomePortal 1000HW DSL Modem and Network Router -1000-400210-000_LN_R (1000400210000LNR)
2wire homeportal 1000hw cannot find wireless address
Please help. I have a 2wire Home Portal 1000hw that is working only with ethernet. I had it set up fine until I changed computers from an xp notebook to vista home premium. The wireless cannot find the address. I have tried to change address without success. Had to guess on default gateway no's to get it set up. I am a student and NEED to move notebook and its been days! Currently connected as Local Area Connection. Got error that tcp/ip cong utility has stopped working but unsure if this has been solved.
Windows 7 (Beta) and Windows Vista 64 Bit. Step 1. Do not allow the autostartup to run the installation application. You must right click on the CD ROM and select the "OPEN" option. Locate the driver on the install CD. Since my DVD ROM drive is my "D:" drive I located the driver at D:\USB_VISTA32364\BACKUP_2WIRE_VISTA_USB_Installer.exe . Before you click on this you want to right click on this and select Properties. In the properties tab click on the middle tab marked "Compatibility". Make sure you select the checkmark box to: Run this program in compatibility mode for: and use the pull down menu to select Windows XP SP2. This is how I was able to get my 2wire utility to work on Windows 7 (beta) 64 Bit.
Posted on Feb 10, 2009
How to access your wifi password with 2wire homeportal 1000hw
If you have the setup menu login password you can view (and change) the wireless connection password in the modem setup menu. You'll need an ethernet cable to connect directly to the modem if you can't get to it wirelessly. With the ethernet cable you bypass the need for the wireless password but you will still need to get into the configuration menu, which usually has a password too. After you connect the ethernet cable, open a browser window and enter 192.168.1.1 in the address field and press enter. This is the same web address field you would use if you were typing www.google.com. That 192. address should take you to the modem setup menu. If a password is required it will prompt you to enter the password. If you don't know the password you'll have to reset the modem and start over. (yes, there is typically an actual reset button although many of them are hard to find) After a reset there is usually not a password requirement. Make sure you set all passwords again if you do a reset - want to be sure no one else can get into your router once you are finished.
Sep 19, 2010 | 2wire HomePortal 1000HW DSL Modem and...
I have a 2 wire home portal 1000HW. We recently had a power failure and the unit stopped working. I have checked the power supply with a vom and it is putting out the rated 6V. I have tried multiple...
Check your current rating on the OEM power supply.. I think your power supply needs 2 amps at 6 Volts. The cheap ones at radio shack are usually only 2 ma.
Jul 05, 2010 | 2wire HomePortal 1000HW DSL Modem and...
I want to identify hardware.
Here is description of the unit , the installation guide and the user guide:
HomePortal 1000HW Router/Modem with Firewall & 1 Ethernet port, highpowered 400mw 802.11b wireless, USB, and HPNA.
2Wire HomePortal gateways include an array of the most common home networking technologies accommodating a variety of service provider and subscriber environments. Flexible networking options include high-powered 802.11g wireless, Ethernet, HomePNAv3, MoCA, and USB.
http://www.2wire.com/pages/pdfs/1000_series_Gateway_Install_Guide.pdf
http://www.2wire.com/pages/pdfs/2Wire_1000_User_Guide.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 30, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Wireless
Your can try changing the channel of the wireless signal by accessing your 2wire Homeportal's interface. try changing it using these recommended channels: 1,5,9 and 11. The channel is usually defaulted to 6 which most of the time conflicts with other high frequency devices.Hope this helps. If you are unsure on how to access your Homeportal's interface you just need to know the default gateway of your device. just go to start>run>type cmd>click on ok>then on the blinking cursor just type ipconfig/all and the number's beside the default gateway is the address of your 2WIRE Homeportal.Just simply open a browser afterwards and access those numbers you found on the cmd prompt. and it should show you the interface of the 2WIRE device.
Mar 25, 2009 | 2wire HomePortal 1000HW DSL Modem and...
Connect panasonic bl-ca10 cam to a 2wire home portal 1800g
Try using WEP instead of The WAP protocol.
It worked for me.............
Jul 06, 2008 | 2wire HomePortal 1000HW DSL Modem and...
How do I set up a home network without internet?
Hi
By default, your wireless connection for your 2wire 1000HW is enabled.Assuming that everything is installed properly in your laptop ie wireless cards etc. than you can view your wireless connection using Dell Wireless connection tool and HP wireless tool. Your know its your network when it says 2wirexxxx {x=combined numbers}. To locate the built-in, 10-digit wireless encryption key for your system, please look at the bottom of the product [2wire] near the bar code label - looks like this : [xxxxxxxxxx].
If you want to access the 2wire Graphic Unit Interface ,you can access it by opening your browser and on your address bar type in homeportal- assuming you are able to connect to your 2wire wirelessly. You can view your network and change you wireless settings. This may also help you :
http://shastademo.2wire.com/rgw3-3/rgw/3-3/homeportal/network/wireless_settings.html
To connect your printer you must have a Print Server [ dep[ends on what model of laserjet you are using } and connected to your printer. Again you will need the encryption key to get it running. You must share your printer on each laptop by going to control panel and share it . In there you willl have the chance to change and modify the settings. You can also use the Windows File and Sharing Wizard. to get it both running.
Hope that would help you a bit. Pls feel free to post your questions in Fixya for further assistance.
Wish you all the best.
Cheers.
Jun 11, 2008 | 2wire HomePortal 1000HW DSL Modem and...
2wire HomePortal replacement necessary?
how bout customizing the wireless settings of your 2wire first for a more stable connection. like change the wireless name from it's default and enable a wireless security. you can also change the wireless channel to minimize interference from other wireless device near your area.
if you have done that already, try to upgrade the firmware of your router to check that it's not a firmware issue.
if you have done everything to solve your concern, it's better to get a replacement.
i believe your home portal is a gateway. if so, you also need to have a gateway to replace it and a router is not sufficient.
as long as your laptop has a wireless card installed, you don't need any other equipment
hope this'll help you.
Jun 03, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Problems with 2wire HomePortal 1000HW DSL Modem and Network Router
Check your firewall setting and also your security settings for cookies. Try putting less of a restriction on your cookies. BofA and wells fargo require that they can ping you and get your IP address incase of fraud so chances are lowering your settings on your cookies will solve the problem.
Apr 28, 2008 | 2wire HomePortal 1000HW DSL Modem and...
Hg1000 home portal
do you mean the modem's ip address?
http://gateway.2wire.net
http://homeportal
http://homeportal/setup
http://192.168.1.254 (software version 3.7.x and higher)
http://172.16.0.1 (software version 3.5.x or earlier)
hope this is the one you're looking for...?
Apr 06, 2008 | 2wire HomePortal 1000HG DSL Modem and...
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
Computers & Internet Logo
355 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
noti13
Level 1 Expert
William Dehn
William Dehn
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
