Question about Creative Labs GigaWorks ProGamer G500 Computer Speakers
Subwoofer powers itself off
The G500 subwoofer powers itself off. I can't manually turn it off and back on and that used to work, but now it won't stay on? Can someone please provide help...thanks.
  • jbvz95010 May 09, 2009
    Solution #1 says its a loose connection in power circuit. Do you take the back off to get to this? My subwoofer goes on lasts for a while then powers off. I can switch the unit off and wait awhile then it will go on for a while then it goes off. I can hear a little click when it goes off - its almost like there is a breaker inside turning it off. also, when I take the power off of it in about 3 seconds the green power light blinks.
  • 129 Answers
I Think its a loose connection in electric circuit. Due to vibration in the woofer the connection might be going off. Check the power circuit for any loose connections.
Posted on Feb 07, 2009
Posted on Jun 27, 2009
I have a vsx44 pioneer and i plug my subwoofer do not work my sub has 2 wires and i have an adapter to plug at the receiver
Is the adapter on the back of the receiver a yellow one (like a tv's red/white/yellow)? And the sub itself is a 2 wire (red/black)? If the subwoofer is just a speaker with no electronics and you answered yes to the first two questions then continue reading...
Problem: New receivers suck and are made for subwoofers that are self powered. The subwoofer input on the receiver only puts out a low signal. The subwoofer itself will amplify the the signal.
Solution: Find a receiver that supports the older subwoofers or do like I did... buy a used 3D surround system for around $10 on eBay, if you don't have one laying around. Be sure to find one that shows a picture of the back so you can verify that it has the 2 wire inputs and supports a subwoofer. Once you have it, connect a cable from the receivers subwoofer output into the surround systems input. It will be only one wire so plug it into the left (white) input on the surround box. You can also use a splitter to get both left/right inputs.
This will enable your subwoofer to be used again and will also give you alot more control over it. Turning off the surround sound box will allow you to keep the bass off when needed. You will also gain individual volume control over your subwoofer this way. I hope this helps!
Mar 01, 2015 | Pioneer Elite 7.2 Channel Network Black AV...
Fuse replacement
The fuse is integrated in hte AC socket. You'll need a small screw driver to pry up the part that talks about the power requirements. Check the online manuals for more details.
Aug 24, 2013 | PSB Alpha Sub Zero Subwoofer
My Sony SA-WM40 subwoofer has power, but sound kicks out. I'll turn off power for about 5min and when turn power on, sound is back. Is something overheating?
Probably, or the woofer coil itself is experiencing a heat, volume or motion related short. Clean any dust or debris from the heat sink fins in the back. Make sure it has lots of space for cooling ventilation.
Mar 31, 2011 | Sony SA-WM40 Subwoofer
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
No sound when hooking receiver to subwoofer using standard red RCA cable. Do I need a subwoofer cable?? I have turned my tuner subwoofer to YES, powered up receiver and subwoofer but nothing.
Probably not if it takes RCA input, but the receiver needs to be informed of the sub's presence and hw you want to share low frequencies among the rest of the speakers and itself. Then you need to set the relative levels using test tones, which also proves the sub works.
http://www.retrevo.com/support/Sony-STR-DH700-Receivers-manual/id/23341dj691/t/2/
Page 102
Set the subwoofer to YES (Page 43)
Jan 17, 2011 | Sony STR-DH700 A/V Receiver
Subwoofer shutting down..
if its shuting down the voice coil is probley bad! u need to replace it ! i got 2 1200watt square subwoofers and they did the same thing . it was the voice coil!
Nov 20, 2009 | Creative Labs GigaWorks ProGamer 5.1 G500...
SA-AX720 no subwoofer signal?
THIS UNIT HAS NO SUB WOOFER AMP IN IT. THE ONLY WAY TO OVER COME THIS IS TO HOOK THE LEFT AND RIGHT FRONT SPEAKERS STRAIGHT TO THE SUB WOOFER AND THEN GO FROM THE SUB WOOFER BACK TO THE INPUTS ON THE BACK OF THE UNIT FOR THE FRONT SPEAKERS. THE SUB WOOFER THIS WAY WILL EXTRACT THE BASS AND THE FRONT WILL RECEIVE THEIR PART. THIS SOUNDS CRAZY AS HELL I KNOW BUT THAT'S HOW I GOT MINE TO WORK. THE OUTPUT FOR THE SUBWOOFER IS USELESS AND PUT THERE FOR YOU TO HOOK UP AN AMP FOR A SUB WOOFER. EVERYTHING HAS SHORT COMINGS, AND THAT'S THE ONE FOR THE AX-720.
Sep 22, 2008 | Technics SA-AX720 Receiver
Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Feb 11, 2008 | Velodyne CT-80 Subwoofer
SUBWOOFER WON'T POWER ON (Grounding out???)
Check your cable that runs between the main unit and sub for bent pins. If they look fine there may be a short in the sub itself that is causing it to go in to shutdown.
Oct 21, 2006 | JVC TH-M505 System
Creative Labs GigaWorks ProGamer G500 Computer Speakers Logo
1,233 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
