Fabric softener dispenser won't drain the fabric softener.
I tried taking the tray out and cleaning it, but it still won't dispense the fabric softener.  I have the Frigidaire Gallery front loader Tumble Action washer.
the fabric softener and bleach will not dispense into the laundry while the cycle is running
  • Anonymous Mar 08, 2009
    Fabric softener dispenser will not empty.  Using a paper clip and a pipe cleaner, I cleaned the holes inside and above the dispenser  drawer. It still will not drain.  I took the top of the washer off  to see if I could easily get to the mechanics if the dispenser....could not.
  • meghann10373 Mar 08, 2009
    Same as described above - our appliance guy said to try using the heavy-duty washer cleaner (Tide makes one, and some other brand, but I can't remember what it's called) because the problem is that buildup in the water lines is keeping the water pressure from pushing out the softener/bleach. I ran two cycles of that & it still doesn't work.
  • 15,935 Answers
It appears your softener tray door solenoid has failed in this instance... or it may be gummed up.
For replacement parts - head on over to or and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Fabric softener drains out, but pumps water back into dispenser after draining?
Hello friend, thank you for allowing me to assist you!
It is a normal operation to receive water inside the dispenser after draining. This is part of the siphoning action of the drawer. You would just remove the drawer and empty the water out, then reattach the dispenser drawer. I hope this is helpful. -Matt
Sep 01, 2014 | Frigidaire Affinity ATF6000F Front Load...
How do I get the fabric softener dispenser to keep from filling with water?
Remove dispenser and clean the drain hole from under neath try with q tip.sounds gunked up.
I just moved into a condo that has the whirlpool #LHW0050PQ front load washer and when I arrived at the condo, I found that the fabric softener tray was clogged. It has fabric softener in it that...
The dispenser asm. has a tab in the rear of it,find it and push it and the dispenser tray will pull out to be soaked and cleaned in the kitchen sink. vinegar could soften it up before going at it with a soft scrub brush.
I hope this has helped you,
Aug 04, 2011 | Whirlpool LHW0050PQ Front Load Washer
#1The fabric softener dispenser won't drain.
Make sure the dispenser is clean and free of debris inside the containers. You may have to take the dispenser apart and clean it out in the sink.
Jun 23, 2011 | LG WM1814CW Front Load Washer
Fabric Softener Dispenser wont drain
Try using a long handled babies bottle brush to clean out the rear of the dispenser and the tube leading down into the drum
Jun 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Not sure if you already did this, but try pulling the face plates off inside the dispencer and take it to the sink and run very hot water into the "stand pipe" that projects off the back of the face plate to make sure they are clear and no old crusty products are in the hole.. Then put them back in and push down hard and make sure they are fully seated.
If the plates are loose and not seated or clogged, there will be little or no siphon effect to draw the fluids out of the dispenser. At least thats how it seems to work
Also, if you pull the top off the washer, there is an adjustment on top of the dispenser to adjust the dispensing ratios I believe.
I just did that procedure the other day on my machine and the wife said it works good now.
Let me know it it works for you, I was wondering if it was just a coincidence.
Jan 15, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Water Softner Dispense wont empty - Kenmore Elite Quiet Pak 4 HE3t
I'm sure you heard a small motor running from time to time during a cycle. That moves an "arm" which sends water to the different chambers during a cycle. Fabric softener is dispensed when water goes to that chamber and dilutes the fabric softener. That chamber then empties by a siphoning action.
If you want to narrow down the problem a little to help trouble shoot -- put some wet rags in and run the Rinse and Spin cycle with some fabric softener. If the softener is not dispensed, then you know that the water isn't being sent to that chamber properly.
If you are intrepid enough to take the top off your washer, do that and see if the arm appears to be moving during a normal cycle. Maybe the arm got dislodged or broken during the move.
If water isn't being diverted properly, I think this calls for a real repair person.
Jan 27, 2008 | Kenmore Elite 45986 Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
2,684 people viewed this question
Top Washing Machines Experts
