Question about Eclipse CD3422 CD Player
Info 5 found an old deck when i was cleaning out a garage. i hooked it up and get radio but the cd goes in and out a while before saying info 5 htf do i fix that
  • 323 Answers
Reading online. This error is due to a faulty motor you would need to contact the vendor to see about replacement of motor or defective unit.
Posted on Feb 07, 2009
CD player works but start delays from 5 minutes to 20 minutes. What could cause that?
Dust inside the cd player could be causing problems.
You need to try playing a cleaning cd and follow the instructions that come with it. You can also spray compressed air to clean out the cd portion of the stereo. You can also try unplugging the unit for 20 minutes and then plug it back in. Make sure your cds are clean and not too scratched up. If the unit is under a year old it may still be under warranty. If this does not resolve the issue you may have to have the unit professionally repaired. If the unit is not worth repairing you may need to buy another unit.
Nov 02, 2015 | JVC UX-T3 Shelf System
I have a Marine Model M235 and need the wiring instructions. I removed a old cassette and hooking up the Clarion CD/Radio. It is getting power but no sound from speakers. This unit has more wires than...
Common wiring for 2 speakers should be.
gray is Rt. +
gray with black stripe is Rt. -
white is left +
white with black stripe is left -
Black wire with crimped connector end is ground for deck. (battery -)
Red wire goes to 12 volt + source (fused) usually connected to ignition/accessories.
yellow goes to constant 12 v + for radio memory.
orange with white stripe, is for illumination. (connect to light switch)
blue is for power antennae if you have one.
May 22, 2011 | Clarion M235-RET CD Player
Cd player is saying PLEASE EJECT and when I press eject cd player automatically turns off, and I am unable to press CD again it will skip to FM AM, and not CD. Please help
it is always cheaper to toss the old radio and install another than to remove and repair and reinstall the old one. replacement car stereo units can be found at junkyards/recyclers, eBay, craigslist, and at flea markets and garage sales.
look on youtube for a video of someone pulling a radio on your brand and model of vehicle, any close year will be about the same. that way when you find a cheap replacement, you will be ready to go.
Feb 22, 2011 | Nissan Armada Cars & Trucks
I hooked up my Sony cdx m-600, all works fine but radio does not work. at all. Why?
make sure the unit is hooked to the antenna correctly. This unit will not play the radio and will disable the static noise on the radio. So ensure the antenna is properly hooked in. For more info on how to use the deck click here for the manual. got this directly off sony's website for model cdx m-600. So let me know if that it is properly hooked up and we can figure out where to go from there.
Aug 31, 2010 | Sony CDX-M600 CD Changer
Have a jvc MX-J500. (purchased as a previously owned unit) When a cd is inserted in any of the three trays it just says "no Disc". Radio works as well as the cassette player. System was dusty but appeared...
You could try a CD lens cleaning disc which will clean any dust off the laser lens. But it is possible the laser power can be low if it is an old player. this will stop the discs being read fence the fault No CD as it cant see the disc. This will mean either a new laser assembly or complete CD deck. Try the cleaning disc first and if that does not work take it to a service centre or just use it as a radio cassette in the garage.
Jul 21, 2010 | JVC MX-J700 3-Disc, Triple-Tray CD Changer...
Need remote codes for AIWA CX ZR 525u Cd/Tape Radio Deck 5 Disk
Hi. The carousel loading belt probably needs replacing - that's why you are "helping" it.
You could try cleaning the cd lens too if it's not selecting an reading cds.
Replacement belts and laser units are on ebay.
Nov 02, 2017 | Aiwa Audio Players & Recorders
I need a radio/cd, that would work with my steering wheel control
im sorry but i must be blunt the people who installed your deck were lazy instead look up factory wheel control module on google there is a system that (as long as the deck has any type of remote) allows you to hook this up run a small wire with a out put laser to the front of your deck acting as a remote control if this infact is not the case use enter in your car information look threw the decks when you find one you like look in eccesorys if its not an option it wont be there :) honestly the jvd avx 820 is amazing for the price check it out it will work with your controls
Sep 24, 2009 | Blaupunkt Alicante CD32 CD Player
I hooked up my Pioneer DVD-5000 to my Amp and all I did was hook up the Remote Wire to the Amp and when I turned on my care my deck doesn't light up or work any more? Did I fry my deck? Can I fix it? What...
sounds like a connection is wrong and if it shorted it prob blew the fuse for the radio. Disconnect the radio from the amp then pull the connecter out of the radio and check the ten amp fuse...
Jul 24, 2009 | Car Audio & Video
Sony output problem
All i did was mess with the REM wire, and found out i had to hook the REM wire to the blue/white wire on the deck. Instead of the blue/white wire, i had it hooked up to the solid blue wire on the deck which was preventing my amp from playing on CD.
Nov 22, 2008 | Sony TA-E9000ES Amplifier
Eclipse CD3422 CD Player Logo
105 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
