Question about Acer X193W LCD Monitor
Shadows my acer x193w seem to be black shadow at the rigth side of every letter and pictures ,when i have a white screen,even when i move my mouse around the shadow follows it, is only 4 moths old
  • 12 Answers
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Posted on Feb 07, 2010
This solution is pretentious at best, and simply wrong at worst. I have a laptop, and am using the Acer as an external monitor. I don't HAVE a power cable at all.
Your welcome.
Posted on Jan 07, 2012
  • xiandude
    xiandude Jan 07, 2012
    Actually, I confess, i misread your solution. You're talking about separating the monitor power cable and the monitor display cable? Really? When pretty much every fifteen pin connection cable is SHIELDED? Sigh... Try again, newbie2000...
  • Jaydeep Nag Jun 19, 2013
    I separated the cables and can see the changes. Thanks a lot for sharing this free solution. God Bless You.
A shadow appears on the rigth side of the frame when in wide screen.
if this is a DLP projector, the light tunnel needs to be adjusted or it if partially collasped.
May 19, 2010 | Office Equipment & Supplies
Letters blurr in spots and black boxes leave a shadow on the screen
Thank you.
Nov 23, 2009 | Acer P221W LCD Monitor
Picture is distorted from center on my 65
You do have a failure in the convergence circuit of your set. If you are good at soldering you can replace the IC's yourself. They are on the large circuit board on the left side of the set looking from the back, and attached to a large aluminum heat sink. If you don't feel comfortable doing that, I reccomend removing the board and sending it to PTS corp in Indiana. They are pretty reasonable repairing boards, and a lot less than buying a new one.
May 31, 2009 | Sony Grand WEGA KDP-65WS550 65" Rear...
Color Alignment
the most common problem when the tv felt is the shadows all over the screen (maybe the tv didnt show it imm but looks like now is there the problem)
second:there is a circuit in the tv that works when the tv turns on every day. prevents the tv showing shadows on the screen.
the answer is this: if that system that prevents shadowing is working then the CRT is broken and say bye to the TV. But if the expert tech can make sure the D' gauss system is not working and can repair it then you get tv back.
Apr 08, 2009 | Philips Magnavox TP3285C 32" TV
Blue shadows on my philips projection tv
You have possibly contaminated fluid in your blue picture tube if it has a hazy look.Blacks and whites look bluish and whites have a blue bloom to them.The other problem could be bad convergence amps.This would be double image around letters on the screen.
Jan 13, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Canon PowerShot A620 Photos have shadows
I was having this problem and found I was placing finger to close to the flash when I was steading the camera.
Aug 23, 2008 | Canon PowerShot A620 Digital Camera
Picture off and shadow of back images.
Hi Grim159
I've had this once on a Epson Projector and the only way I could this right was by replacing the Mainboard.
Hope this is of help.
Apr 22, 2008 | Philips ProScreen 4600 Impact Multimedia...
Left side of television just started having a shadowing problem?
I have the same problem and was told by a technician that I need to replace the light engine. Probably around $ 700.00.
Oct 15, 2007 | Samsung HL-R6167W 61" HDTV
Acer X193W LCD Monitor Logo
569 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
