Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
S video cable not recognized on Hitachi flat screen
I ran an S video cable from my Comps Nvidia graphics card to the S video input on my tv set. I set the Graphics to clone. Yet I can not figure out how to get the TV to pick up the signal..
What i am trying to do is project what is on my Comp to appear on the Flat screen.
The TV is a 42'' Hitachi flat screen.
I went through all the Menus input options. I think, But none say anything about the S video connection..
The comp is a Dell 521I and the Graphics card is a Nvidia 7300 LE
I thought the TV had two S- video inputs... It doesn't. Pne of them was an out put and it was there that i had it plugged in. Once i switched it over everything was fine.
Posted on Feb 09, 2009
S-video out to tv nvidia 9300 gforce won't work
obvious things first. have you tried the other input plugs on the TV? do you get the same problem with plugs 1 and 2?
you can try only having the TV connected to the Graphics card and turning on the PC see if it comes up as the primary display automatically.
have you tried configuring the Nvidia setting so ONLY the tv is a display instead of dual monitor?
doing these will rule out faulty cable or faulty S-video plug or Faulty TV input plug.
Dec 07, 2012 | Nvidia 64MB GeForce3 AGP Video Card with...
I have a nVidia Quadro2 MXR/EX video card which works fine on the analog input but when you use the digital input the screen sometimes flashed at startup and then goes blank. If you move the mouse,...
There are a few things that come to mind here. Number one is to try a different and known functioning DVI cable. Maybe see if you can recreate the problem simply by wiggling the dvi cable. If there are any splitters/adapters, remove them and plug the cable straight from the video card to the display. Make sure the display is set to digital input mode. When you are using the digital cable, make sure to completely remove the analog cable. See if this problem happens outside the operating system (such as in the system bios, if it does, this indicates a hardware issue). Finally, the digital input on the monitor could be having an issue, try a different monitor or try this monitor with digital input from another system.
Sep 24, 2011 | HP NVIDIA Quadro2 MXR (32 MB) AGP Graphic...
I put mu s-video cable in the comp and in the tv and there is no signal and picture,like nothing happens i tried i settings ang graphic prop and there is nothing that i can klik ti say tv ???
make sure your tv is set to the correct avi or input that your using for the laptop conection to it. hope this helps, normally should just come onto the tv. once the tv is on correct station so to speak.
Dec 04, 2009 | Nvidia GeForce FX 5200 Video Card Graphic
PC Wont Show up on TV Screen
Have you set the properties from your computers graphics settings ?
They have to be set first and it is always better to start with a lower resolution first.
First off ensure it is a good quality cable as many cheap cables are not worth the material they are made from.
Second you will have to make sure you tv is set to the correct input eg video 1, input 1, etc.
Third you need to call up the display properties for your graphics card on the computer
You can right click on an empty area of your desktop and if there is an option for Nvidia or radeon you should use that.
If not click on properties. setting, advanced, you should then see a tab for your graphics card, select this.
Options may vary a little from here on but you are looking for an advanced control panel just for your graphics card and it is in this area that you can select additional displays and their properties. Usually it is best to select "clone" until you have established a picture. after that you can select expand or other options, Clone is usually best.
You should also find the option that lets you set the resoloution for each screen independant. then you can select the flat screen and say set it to 1024 x 768 as a starting point whiles leaving your regular monitor as it is.
You should by now have some form of display on your TV. It may look wrong but once you have it you can alter the resolution until it fits as you want it to.
The aspect ration on your big tv may also need to be changed so that you can get the computer image as large as possible without loosing any of it eg. the toolbar
If you have an Nvidia card then you are better using the "dualview" option to do what I just described Radeon may have somthing similar but I am not a fan of that brand and find the Nviia easier to use for this type of work.
If your graphics card has a digital output then a lead from that to your TV if it too has hdmi etc is a better option than S-video, Some TV's also have a VGA input this too is better than S-VIDEO.
Aug 11, 2009 | Olevia Televison & Video
Com to tv
do you have the card set up to use the s-video cord?nvidia control panel will help you do this.
also make sure your tv source is set to s-video input selection.
Jan 28, 2009 | Nvidia GeForce4 MX 440, (64 MB) Graphic...
Trying to connect a sharp aquos lcc3234u tv to pc using hdmi
it sounds like your computer isnt set up to send the signal out. try right clicking on your desktop and selecting a dual monitor setting. It should be found under graphics options or something similar.
Jan 24, 2009 | Televison & Video
No signal on HDTV
Your graphics card is probably too old to support HDTV signal (720p, 1080p)
Dec 04, 2008 | Nvidia GeForce FX 5200 Video Card Graphic
Monitor resolution
when you increase considerable resolution windows will ask you do you want to keep these settings? you select yes then that will be saved
Feb 15, 2008 | ViewSonic VX2235WM Monitor
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
