Question about Kenmore Refrigerators
Top part of refer only cools to 39 on max how can i get i cooler
How to correct
    President:
  • 1,902 Answers
You may only be able to do this if the thermostat is not bad or the compressor is not leaking fluid
Posted on Feb 07, 2009
Oil getting into radiator/cooling system?
Hi Alan, If your vehicle has been overheated at any time, the cylinder head may have become distorted and consequently coolant may be mixing with oil if the gasket is damaged and failing to seal correctly. The job requires the removal of the cylinder head and taking it to a machining company to skim it before replacing. You were quite correct to have checked the oil cooler if it is the type which fits into the engine block and uses the engine coolant for cooling. Oil in the cooling system is not something which should be ignored. Once the problem has been solved and rectified, flush the cooling system to remove all oil deposits and then use the correct mixture of coolant to water. Regards John
Oct 20, 2012 | Renault Cars & Trucks
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
HH error code? on magic chef mcbc580dbt
I, too, have just seen (late June 2013) the "HH" code on my Magic Chef wine cooler (and it is running too cold and I can't reset the temperature). Have you found a solution since your posting of about 1 year ago?
Jun 27, 2012 | Magic Chef MCWC30MCG Compact Wine Cooler
Master cool not cooling. Outside air is dry and temp between 100 and 108. Fan working, water pump working. Water pan is full. Water flowing to top of padPad gets wet but only lightly. Air from cooler...
I would bet that the problem lies in what you said about the pad. It needs to be well-soaked for the evaporative effect of the unit to do its job.
You give no model, but if you disassemble the unit (only the top panel) at the water distribution tube and expose it you can see what's going on. Water flow will be minimal.
The tube disconnects from the water supply tube at one end.
Disconnect it and, carefully since it's plastic, clear debris out of the distributor.
If it's like mine, it will have a fair amount of scale built-up in it. Once clear, re-assemble and start the unit.
Jun 28, 2011 | Heating & Cooling
We have an older swamp cooler and need to have some windows in our home open to get best cooling. Does a mastercool need to have some windows open in our home to give max cooling?
The solution is to install "up ducts" These devices are easy to install and are fairly cheap. With a swamp cooler the best way to use them is to allow them to draft outside with the "up duct" you get the drafting to the outside but also get to remove attic heat too.
Apr 24, 2011 | Mastercool 67680 Evaporative Cooler Air...
Qets way too hot - i have turned the dial all the way to cool and "stand by" not sure what that is but its not getting any cooler? We bought it used and have limited info on it, the reference card says...
This would indicate that the heater relay is stuck in the closed posistion giving constant power to the heating element.
Either that or thermostat dial is broken
Sep 11, 2010 | Qca Spas Jewel Series Topaz Plus Hot Tub
Kenmore wine cooler 13485 spill wine in the top not cooling
if suction line is warm and pressure line hot . sounds like comp is trying to do its job / ck the fans and they may be slow or not going . spilling of the wine did not cause problem . .. but now is the time to correct the problem .. mm / ps if unit is running like you state the you might look at the ref charge . as it may be low . mm . hope this hs helped . feed back pls .. mm
Jul 22, 2010 | Kenmore 13485 Wine Cooler
Coleman Electric Cooler doesn't stay cold
the most common problem is that one or both cooling fans has failed. If you have the newer version, you can get replacement fans anywhere computer parts are sold
Jul 03, 2009 | Coleman Electric Cooler 40 Beverage Cooler
I have a 97 Lincoln Continental. I am trying to replace the cooling fan. I have the shroud loose but can't figure out how to get out. Any help would helpful. Thanks
YOU NEED TO TAKE IT OUT FROM THE BOTTOM REMOVE PLASTIC SHROUD THEN DRIAN AND PULL LOWER RADIATOR HOSE FROM RADIATOR AND THE REST IS PRETTY SELF EXPLANATORY MAKE SURE YOU BUY THE CLIPS FOR THE WIRRING BEFORE YOU EVEN START
May 09, 2009 | 1997 Lincoln Continental
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
