Question about Whirlpool Washing Machines
Washer will not fill or wash
Replaced control board
  • 2 more comments
  • trarica Feb 07, 2009
    whirlpool model # wfw8300sw03 front load washer
  • trarica Feb 08, 2009
    washer is giving error code F 30 Should I replace the acuator despenser ? Would that prevent the water from entering the washer ?
    fetting error code F30 should I replace the Acuator Dispenser ? Thank you for your help...
  • onthethejob1
    onthethejob1 May 11, 2010
    model number please
  • 640 Answers
Theres 2 boards in unit console,,you should have replaced the control on the right side with the door switch..if replaced control board on right side just check door switch..onthejob
Posted on Feb 08, 2009
  • onthethejob1
    onthethejob1 Feb 08, 2009
    first check the inlet screen..they may be clogged
Water still running when machine is off, what to check for
Here is what you can do to determine what part you will need to replace. Turn the washer on and let it fill with water on any wash cycle. While it is filling with water unplug the washer (power cord to the outlet). If water continues to enter the washing machine it means that the washer inlet valve will need to be replaced. If the water stops filling when the washer is unplugged then you will need to replace the timer or control board which powers the valve.
Oct 23, 2016 | Washing Machines
I have a 6 year old Frigidaire washing machine. It does not fill with water. All water lines have been checked and are okay. Washer goes immediately into the wash cycle without filling with water.
This is symptomatic of a malfunctioning water control valve- the hot water one if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else like the control board or connectors ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
Kenmore 80 series washer will sometimes not fill in rinse cycle, sometimes half fill, sometimes 1/4. fills fine for start but not rinse????
HI, This will be the result of a failing control sector. The control sector can be a timer module, or a single printed circuit board. In any case, this will be your culprit. Have this damaged control replaced, asap. Once replaced, your unit will operate correctly.
Dec 26, 2009 | Kenmore 24032\24036 Top Load Washer
Stops on fill cycle
HI, this is a common issue concerning this control board in your unit. this is a control fault and, you will need to replace this failed control board asap. the logic chip set is damaged.
Jun 11, 2009 | Maytag Neptune MAH5500B Front Load Washer
F1 error code on Kenmore Oasis He
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jun 02, 2009 | Kenmore Oasis HE 27082 Top Load Washer
1999 maytag neptune washer stops after filling up with water
There are a couple of common causes for a problem like this. First is a bad door lock assembly that also damages the machine control board (in the control panel). If this is the case the R11 resistor on the machine control board will be burnt.
Maytag has identified seven resistors that relate to specific components that need to be checked or replaced if the resistor is damaged. Listed here are the resistor identification, the circuit involved, and the recommendation:
R9 / pressure switch / check for loose connections or high resistance on switch contacts; replace pressure switch if necessary.
R11 / door lock wax motor / replace door lock mechanism and machine control board.
R51 / hot water valve solenoid / replace water valve and machine control board.
R52 / timer motor / check for loose relay terminal connections and replace machine control board.
R53 / cold water valve solenoid / replace water valve and machine control board.
R143 / (-) 24 Volt DC / contact was made between neutral and the 24 Volt DC circuit.
R162 / electrical buffer circuit / wire harness and machine control board.
Another common issue is a slow water fill fault. If the washer does not fill within a certain time the control will stop on a fault. Usually when this happens the START button can be pushed to continue the cycle.
Washing machines that won't fill or fill slowly often have a restriction in the incoming water supply -- usually in the screens of the inlet hose washers or the water inlet valve itself. Remove the hoses to inspect this condition. If the water inlet valve screens are plugged, replace the water inlet valve.
Go here for: Maytag Neptune Washer Parts
RepairClinic.com
Appliance parts, help & more
Apr 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Washer will not fill to appropiate levels
If " Washer will not fill to appropiate levels " this has nothing to do with drain pump and control board is unlikely.
That sounds like a water level switch that is malfunctioning, or a badly connected control board, call back the technician and tell him to double check the job done on control board.
Jan 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washer fills, drains, & final spin
Make sure the tub us actually moving. Sounds like the belt may have come off. That is what has happened to me.
Mar 13, 2008 | Splendide 2000S Vented Washer/Dryer
Filling With Water
"preesure switch" built into controller, remove 2 screws behind console nad check the clear hose hasnt become diconnected, or perhaps has a crack in it not able to "read" water level
Mar 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Dec 18, 2007 | Washing Machines
Washing Machines Logo
88 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
