Question about Altec Lansing M604 Computer Speakers
Dock Power Cord is broken, where to get a new one!
Well, one day I try to plug in the wire cord and one of the metal sticks get bent, 2 days later all of them are bent (in the power cord end) and I want to know where to get a new power cord
  • bigglizz2 May 11, 2009
    SAME PROBLEM POWER CORD BROKE NEED A NEW ONE
I had this problem - i called customer support and was sent a new cord FREE of charge. Just call customer support 1 800 258 3288!
Posted on Feb 24, 2009
    Problem Solver:
  • 7 Answers
Just take the cable that you have got and take it to you local computer store or best buy and show the cable to the sales assistance and im sure they will have it,.
Posted on Feb 11, 2009
Pride Jazzy 1103 Ultra: Bought used and came with new batteries. Worked fine until a week or so ago. Then died and couldn't be recharged (on-board charger). The seller kindly sent an external
a cheep fix is the charger I am showing you from Advance auto it will bolt into stock location and bolt to battery post you will need to make a jumper wire to send batt. voltage to joy stick controller well worth doing the modification to save big $$$$.
Dec 20, 2014 | Pride Jazzy 1103 Ultra Standard Power...
No power to switch. ts there a reset button?
Check the power plug cord, might be bent so often that the internal wire)s) are broken. You can cutoff old plug and replace with new one.
Jun 08, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Fan goes to slow speed when power cord is bent near unit.
This is a sign that the wire is possibly broken inside the insulation and would cause an amperage drop causing the fan to run slow. I suggest that you replace the cord with a cord of the same wire size and new plug. Myself I like safety factors so if the cord says it is #14awg go to #12awg and use a twenty amp rated plug be safe not sorry.
Dec 13, 2010 | Pelonis WM-B-6A1 Ceramic Compact Heater
One day, I pressed the "on" button and it didn't start...had no problems whatsoever before.The inside hose is clear-fan turns-no visible breaks in the electrical cord or plug...
You need to measure for voltage inside the machine between the white wire and black wire from the power cord. If zero, the cord is likely broken at or near the plug end. This is a common problem if one pulls the plug by yanking on the cord instead of pulling on the plug directly. In any case, try cutting the cord off a little way back from the plug, and fit a new replacement plug from a home center or hardware store. If the voltage test above showed line voltage (115 volts AC in the US), then turn the switch to on, and measure for voltage between the white wire and the motor side of the switch. If good, then likely there is a motor brush problem or a broken winding in the motor. Repair of this usually requires dis-assembly of the housing around the motor. Hope this helps!
Oct 04, 2010 | Kirby Generation 3 Bagged Upright Vacuum
Trimmer won't operate, is less than year old. Connect to cord and won't operate
Try something else (a lamp) in the extension cord. If ok, the case must be opened to expose the wiring. Check for 110-120 volts AC at the cord ends. If nothing, the plug end may have a broken wire. Cut back the end somewhat and install a new plug or just replace the power cord. If still nothing, remove the power connection and ohm-check the switch and motor. The switch should read zero ohms when on and the motor will usually read less than 20 ohms if good. If either reads infinity, replace the switch if so, and check the motor brushes for sticking or bad springs.Hope this makes sense and helps!
Apr 17, 2010 | Garden
Power cord plugged in no lights on power brick
ring xbox tell em u didnt do anything to it and its just broken they sent me a free new one :) so they should u it was with me after 2-3 days
so get a new free one and end any future problems
Sep 01, 2009 | Microsoft Xbox 360 Console
Magellen RoadMate 700 will not power up
if your sure its charged,(is the green light on the car charger) hold the power button for upto 15 seconds till it starts.
Jul 19, 2009 | Magellan RoadMate 700 GPS Receiver
Last night my 2 wire router stoped working. The
your rooter must have a reset button on it. Considering that there was a red light on, it sounds like it is off rather than dead. There are only a couple things to try, the reset I mentioned, and the other is a power cycle. Disconnect everything the input line, the power cord and any thing else that is connected, and wait 5 minutes to reboot and connect everything.
Mar 26, 2009 | 2wire (1000-400108-001) Router
The plug to the tv broke off!
One way would be to go to a store that sells electrical parts and buy a replacement plug and install it.
The other would be to replace the whole cord, much more time consuming and probably a bit more expensive. I'd just go and buy a new plug.
Oct 07, 2008 | Televison & Video
Power Issue
sounds suspiciosly like your chord fitting is damaged(loose wires at connection)and shorting.if possible try a friends power supply with same connecter type before renewing cos could be faulty(loose)connection at pc(inside)constant pushing and pulling of connections often causes 1. loose split or disconnected wires at male connection or 2.loose pins on motherboard female connection or broken housing (not difficult to repair)more difficult to find out how to get to internal connection.
Mar 04, 2008 | Toshiba Satellite M65-S9092 Notebook
Open Questions:
See all Altec Lansing M604 Computer Speakers Questions
Altec Lansing M604 Computer Speakers Logo
1,383 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
