Question about Moen Plumbing
No warm water in showers
I just moved into a house that has two shower with the same fixture, a single rotating nob that, I assume, is cold on the right warm in the meiddle then hot on the left.
On one shower, there is only a trickle of cold water on the right, then hotter and hotter water as I turn it left.
On the other shower there is lots of cold water on the right, lots of hot water on the left and absolutely no water whatsoever when it's pointed straight up?  Do I have to proken fixtures or is there a larger plumbing issue involved here?
  • TMQuinn Feb 08, 2009
    I do have hard water though, I live in Las Vegas. I've attached a photo and I'd like to fix it myself, but I couldn't even figure how to get the plastic knob off...
  • Thomas F. Schneider May 11, 2010
    I have been thinkng about you problem this afternoon and if you have hard water I believe that the passages are blocked. The one that has no flow in the middle position may have the internal part installed upside down. Turn off the water, take them apart and see what is happenng.  Most parts like that are made of plastic and are not hard to find or replace.
  • 34 Answers
Pleae do not follow smthbrother's advice. It is just a simple problem with the valves, nothing to stress about. I am a plumber by trade and see things like this all the time. If you post the name of a pic of the valves I can tell you what you need to buy and how to fix them if youwant to take this on. If you feel this is something you might not want to I can figure a price up to repair it..this will give you an Idea of what it should cost when you have someone come out to repair it so you dont get taken. Repost if you need anything or you want me to walk you threw it.
Posted on Feb 08, 2009
Hot water pressure is weak. Shower head isn't clogged. Cold water pressure is good. How do I increase the hot water pressure?
Is the hot water pressure good at other fixtures in the house? I'm guessing your newer valves have a scolding adjustment that is set very low. Check the instructions that came with the valve assembly.
Feb 10, 2016 | Danze & Single Handle Tub And Shower...
The shower only runs hot water no matter where the handle is turned...even on the cold setting.
You need to replace the mixing valve. It's not terribly hard to do, if you have some tools and, if the valve is not stuck in the fixture. Here's a video on how to replace it. Take note of how the tabs on the valve are positioned so you can put it in the same way it came out. If cold and hot water are reversed, you need to take valve back out and rotate 180 deg. and put back in:
http://www.youtube.com/watch?v=J-SNBNijfQc
Dave
This is assuming you have hot water elsewhere in the house and not ot the shower. Check to make sure you have hot water at other faucets.
Jul 03, 2011 | Moen & One Handle Tub & Shower Faucet
I purchased a Moen L82691SRN "shower only" fixture. I hooked it up and can only get cold water to come out of shower head. When I turn the handle to the "hot" side it will only trickle...
You have purchased a scald guard faucet, that you will have to set for your own house. If you take off the handle and face plate and look down there should be a plastic part (usually a deep blue) with teeth. It restricts the hot water side of the unit. If you pull it out and rotate (about halfway) you should have water flow. If it is still not hot enough rotate it more, or less.
Jun 26, 2011 | Moen Home
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Delta 13022 - Hot water out of the shower is much cooloer than out of the sink faucet. How is the mix of hot & cold controlled?
The Delta shower has a rotational limit stop designed so that when another fixture is activated, such as a toilet or dishwaser, the water does not go to extreme hot or cold. The reason for this is that the Delta shower unit is not pressure balanced or does not contain an anti scald device. The pdf document below will show how to adjust the water tempature if you feel it is too cold. Please use caution as it is probably set the way it is to prevent scalding.
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevH_4.15_15e05.pdf
Aug 03, 2010 | Delta T13420 Chrome Classic Single Handle...
Just had a single handle shower faucet installed in my new walk-out developed basement and it seems there is a control on it I want to remove. I can't get the handle to go beyond mid-point and I want more...
Hi im Rossouw
The rest of ur house water in the showers fine?
If not they must install a prv (Presure reducing velve) on the cold going to the house and geyser befor it t,s of to the house and even if the rest of the house water is fine u must ask ur plumber who intalled it if he took the cold water going to the new shower strait of the mains if so he must corect it by t-ing in at the right cold water supply or put a velve on the cold water to ruduse the cold presure . then u will have more hot presure and that means lovely hot shower
plz vote and rate my advice thanx
Jul 17, 2010 | Delta & Single Handle Shower Faucet
Not enough hot water, has to do with a shower valve
Hello, first if any water supply hot or cold is turned off, you will experience trickling as you mention. You must have both cold and hot in order to adjust the temperature on your valve. if you had a plumber intall this unit you should ask him to adjust it. Otherwise here is how:
Rotate the handle counterclockwise to stop and let water run till cold water is purged, check
temperature. Rotate handle to off, remove handle parts (see Disassembly in your manual) and temperature limit stop, rotate clockwise to decrease and counterclockwise to increase maximum hot water temperature, reinstall temperature limit stop and handle (TIP: Do not screw handle in until desired maximum temperature is achieved) Repeat steps until desired maximum
Feb 21, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Kohler 30 year old single handle shower valve - cold water only
Is this a dual handle or single handle? if it is a single handle
turn the valve 180 degree. if not, then check the cold water supply line.
Jan 02, 2009 | Home
Plumbing Logo
150 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
