Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
No power on LC32D50U Sharp
The power light blinks, but tv will not turn no. I have replaced the power board, did not solve the problem.
  • 1 more comment
  • sallyannmcdo Feb 27, 2009
    When trying to turn on the power light on screen and base goes green fpr a few seconds then back to flashing red and full red - will not turn on., Checked all cables but no joy.
  • glennac Mar 03, 2009
    My receiver seems to be getting power (red light is ON on the front of box. But the Display will not power up. No red light - nothing. Tried the "Reset" and "System Reset" (described in the manual) but no go. Switched the power cords on the Receiver and Display, but no difference.
    Why are the other two reports here dated this month? (Feb 2009) Seems odd.
  • Anonymous Mar 07, 2009
    si accende regolarmente ma non si vede nulla.
    Posso cambiare i canali ma non si visualizano.
    dopo circa venti giorni riaccendo il tv e tutto funziona regolarmente.
    dopo qualche mese di nuovo spenta.
This is glennac. I figured out what happened and thought I would update for others. The display had stopped working soon after mounting it to a wall mount. I discovered, when I began removing it to take it to the shop, that it started working again once I had loosened one of the mounts screws. Tightening it back in caused the display to lose power again. What I discovered was that there is a spot on the back against which the mount plate rests which, if pressed too hard, cuts the power. Backing the screw out relieved the pressure on this spot and now the TV works again. Facing the back of the display, the spot is at about the 11:00 o'clock position from the center, halfway between the center and the top.
Posted on Mar 15, 2009
2 Suggested Answers
  • 152 Answers
SOURCE: No power on LC32D50U Sharp
bobnyc, Is set under warranty? How old is it? Did it display a "perfect" picture yesterday, and not today. How is or was the AUDIO. Can you hear anything or nothing? Is the SMPS power supply board a "COMBO" or is the INVERTER supply located elsewhere? To where do the CCF tubes connect to get power? Tell me, do u have a good DMM, 100mhz Ocilloscope, Isolation transformer, and soldering iron/ solder wick???? If have some answer to some these ??? contact me @ louie12fix on fixya or at lmistyrel @aol.com PS: I highly recomend use of digital cam to take pic's before taking stuff apart. Could help when reassembling.
Posted on Mar 29, 2009
Power light blinking no display on lc 32sb24u
Its almost always caused by bad capacitors on the power board. You can get a repair kit or the replacement power supply board from www.tvrepairworld.com
Feb 12, 2012 | Sharp LC-32SB24U 32 in. LCD TV
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
TV won't turn on
the first thing that you need to do is to open the back cover of your tv.Go to the power supply section it is separate board where the power cord is connected.Using a multitester,plug in the power cord and measure for the output supply.see if the 5vdc ,12vdc and 24vdc are present..if one of this output is missing,replace the power supply board But if the output voltage are complete,replace the inverter board,It is a board that supplies the high voltage to the backlights of your monitor/screen....You can also try to reset the system of your tv by pressing the the small switch mounted on the main board press it twice while the power is on...tnx and good luck!
please vote for my help!
Jun 04, 2010 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Mar 29, 2009 | Sharp Aquos LC-30HV2U 30 in. LCD...
Sharp Aquos LC-30HV4U
replace the supply board
or repair it *** there's problem with supply
Jun 13, 2008 | Sharp Aquos LC-30HV4U 30 in. LCD HDTV
No picture, but power is on...
How many times does the POWER led blink per sec? (dont worry about the OPC)
2x = power supply (not as expensive to fix)
3x = Main board (expensive to fix)
Oct 20, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
181 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
