Question about Philips Audio Players & Recorders
Record PIN needs to be changed, where can i get spare in Bangalor
My Record player plays fine, but the PIN has broken. I need to replace it with a new pin. Please let me know from where I can buy the PIN and can get it fixed into the player.
    Sergeant:
  • 306 Answers
It is called a stylus and is part of a cartridge. There is a small release lever or it comes out as a plugin device. I cannot see where you are but eBay will have your stylus/cartridge for your turntable if a stereo shop is not nearby. Also any TV repair shop can order it for you. Steve Medley
Posted on Feb 08, 2009
The dvd has started playing everything green. We never record and have only played about 25 dvds in it.
Sounds like the settings for the dvd output have been changed. Need to have it re-calibrated.
Apr 08, 2015 | Audio Players & Recorders
I have a Kenwood KR V6090 tuner amp. Can anyone please tell me if I need a record deck with or without a pre amp fitted.
Hi. Some amplifiers provide power for a record deck (or you mean a vinyl record player). Some vinyl record player have their one amplification system, some don't. Those with the amplification system work fine on older amplifiers but others require a back-up power, like a transformer to provide power for the record player. You need to enquire with the store person on the type of record deck or record player you can use directly with the V6090. I had an early Pioneer Amplifier and a matching record player so that I could play the vinyl disc and LP's on full volume. Later I switched to digital Pioneer 7 channel. This couldn't accept the record player because it did not have a power substitute like the older Pioneer. So, when the record player plays, no signal is being sent to the amplifier and therefore, no music is heard, except from the needle.
Dec 12, 2014 | Kenwood Audio Players & Recorders
I have a brother xl5012 and would like to change the spool pin..not sure if its broken? the one on top is silver and the spare is plastic..not sure what to do..the manual has no answers.. thank you
On most machines, the spool pin simply screws into a threaded hole. If it was welded on or attached in some other permanent way, changing it may need a service visit. Brother has one of the very best service departments of any company I know. But try to unscrew the old one.. it might be stuck, a drop of penetrating oil, or maybe some pliers, might assist. If it comes out, a new one should screw in easily enough, so long as it matches the size of the hole and the threading.
Nov 17, 2014 | Sewing Machines
Record button will not push down with play button, to record.
Are you using a new cassette???? Check to see if the tab is missing on top of the tape.....If it is put tape over it
Mar 14, 2012 | Memorex MKS5009 Karaoke System w/CD/CD+G...
Broken needle on thorens TD 158 turn table.
Needle is a term used with 'record players' from the 60's. A turntable has a Phono Cartridge with a stylus. Depending on the brand / model of said cartridge the stylus may be replaceable. The cartridge certainly is. The tonearm is a delicate precision mechanism that will last lifetime if handled properly.
If you don't understand any of this I discourage you from taking any further actions without a knowledgeable mentor / technician looking over your ahoulder.
Mar 22, 2010 | Audio Players & Recorders
How to record dvd in ordinary format?
I will presume it plays back fine on your dvd recorder.
In this case, you need to "finalize disc" for it to be playable on other dvd players.
Also, possibly, If you are using a dvd-ram disc, you must make sure that the dvd-player you are trying to use even supports dvd-ram. Most will NOT.
Also, Make sure you are not recording in VR mode. Only some very new dvd-players will support VR mode discs.
Jun 01, 2009 | Pioneer DVR-550HS HDD Recorder
VCR will play, but not record.
You gotta connect the signal cable to the input of the vcr and in the output of the vcr other cable to the tv input,when you got to record some program you need put the channel number on the vcr not in the tv if you conect the vcr to the tv in the avinputs the tv will be in video mode,because the vcr receipt the signal.
Good luck
Apr 13, 2008 | Samsung DVD-V5500 DVD Player/VCR
Getting a dvd player to record vhs to dvd
The RF converter takes the Red/White/Yellow as INPUTS and converts them to either channel 3 or 4. You need to go the other way. You need a tuner or another VCR to convert from RF (channel 3 or 4) to a standard AV signal (Red/White/Yel).
Dan
Mar 19, 2008 | Sanyo VHR-5431 VHS VCR
125 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
