Question about HP Office Equipment & Supplies
I had an obstacle on the HP 1200 Laserjet and printed. The paper was stuck, I pulled it out and the yellow light has been on ever since. Turned it off and on again. Still doesn't work.
  • 628 Answers
You may have left a bit of the paper in the printer.
Posted on Feb 07, 2009
Hpllaser jet 1200 paper stuck in the back I had try to pull it but I can barely see it there, i can't see it from the front
You might use a tweezers and try to pull out the paper. The paper is stuck by a sensor, and if you can clear that sensor, the machine will start up, and transport the rest of the paper out. Be carefull and try not to hurt the fusing rollers, while picking with the tweezers.
If it's no good, you have to disassemble
the fuser-unit and remove the paper, or in worst case, replace the fuser unit..
May 10, 2012 | HP LaserJet 1200n Printer
When printing on HP Laserjet 1320 it brings the red light and it does not shows any error. no printout.
there is a paper in it's roller to remove it pull out the tonner and check the roller ther will be a paper stuck in it remove that papre printing will be contnue
Jan 19, 2011 | HP LaserJet 1320 Printer
Paper printing and get stuck n when i print only 1 page, it grab until lot of paper n suddenly jammed.. what is the actual problem what should i do? hp laserjet 1200 series
sir
I guess you maust replace your Suser Assembly, or at least regrease the fuser roll.
try to go to service center , or download the service manual from the internet
regards
walid sayed
Egypt
Mar 16, 2010 | HP LaserJet 1200 Printer
LaserJet 1200 Stops pulling paper
If the printer works fine for you, but doesn't work properly for someone else I would assume user error. Just make sure that there is plenty of paper in the tray and that it is centered. Also look around for any small peices of paper that might've gotten stuck near the tray, preventing new sheets from getting pulled.
May 06, 2009 | HP LaserJet 1200 Printer
Orange light is flashing
I cleaned out the printer by removing any access toner. Made sure again no paper was stuck and then it worked.
Apr 14, 2009 | HP LaserJet 2100 Printer
Will not print after pulling forward a jammed paper
make sure the paper didn't tear and a peace got jammed somewhere in there. then reset the printer.
Feb 09, 2009 | HP LaserJet 1200n Printer
HP 1320 will not print
hi..
what about the ink levels...open the backdoor of the machine and check for any obstacle....disconnect all the cables..press and hold down the power button for 30 sec..reconnect all cables..try again...try connecting the machine directly to the walljack.
Nov 25, 2008 | HP LaserJet 1320 Printer
Printer problem - will not print
I found a piece of paper jammed in the printer. Thanks!
Nov 21, 2008 | HP LaserJet 1200 Printer
Hp laserjet 1200 series
Remove the DIMM and reseat it.
If the printer still has an error, replace the DIMM.
Unplug the power, reseat the paper tray, and reattach the power cable.
Oct 20, 2008 | HP LaserJet 1200 Printer
Paper jam
There could be a tiny piece of paper blocking the paper path or sensor. See if you can find any.
Jun 30, 2008 | HP LaserJet 1200 Printer
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
