Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine previously off balance, I pressed cancel button
To stop machine and then took clothes out. Today I tried to used machine closed the door, pressed start on the machine and machine will not start nor will the door open. the door is locked
  • 5always Feb 08, 2009
    I have the same issue.....and my kids need at least one pair of the jeans in there, so tried everything.......no luck.......Repairman from Best Buy (warranty still, just by months) coming Tuesday, but it's only Sunday! There has to be something that lets us open that door!!!!!! HELP!!!!!!!!!!!!!!11
THERES A LOCK/UNLOCK TO THE FAR RIGHT OF THE PANEL..HOLD IT DOWN FOR 3 SECONDS - MY KIDS DID IT TOO
Posted on Feb 12, 2009
Smart drive 601
If it is out of balance it will automatically return to a wash cycle to try and redistribute the clothes more evenly. Maybe the out of balance switch is faulty. More likely though is a faulty control board. If that then get a new washing machine. That model is over 20 years old. Not worth spending money on it.
Jan 23, 2018 | Fisher and Paykel Fisher & Paykel Washer
My washer machines door is locked wont open. And won't wash the clothes in them
  • Unplug your Maytag washing machine for 30 seconds.
  • Plug your washing machine back in, and after 30 seconds, push the "Pause/Cancel/Stop" button two times. Choose a wash cycle.
  • Press the "Start" button until the wash cycle begins to ensure that the washing machine is functioning properly
  • Nov 09, 2012 | Washing Machines
    When the WP model WTW6600SW0 completes the wash cycle the clothes are still soaking wet. We have been running the clothes through another spin cycle, sometimes a second spin cycle to try to get the water...
    You need to access your fault codes...pick any button but start or cancel and do the diagnostic test.
    Press and hold for 4 seconds/release for 4 seconds and repeat this sequence till all the lights come on.
    Press that same button to toggle thru the 5 most recent faults.
    Post the fault codes back to me here.
    Oct 16, 2012 | Washing Machines
    My washing machine will not power on
    suspect lid switch but call a repair service locally to have it checked properly
    Dec 15, 2017 | Fisher and Paykel GWL11 Top Load Washer
    My hoover galaxy washing machine stops when clothes are not balanced properly.i have to even out the clothes then start the machine.if the clothes are balanced it finishes its cycle.if not the machine...
    Hi
    It is normal for the drum to sway excessively and hit the balance switch if the load is not evenly distributed around the drum or if you have excess cloths.
    Once the balance switch is trigerred, you can reset by openning and closing the door. It is a safety mechanism which stops the spin cycle if the drum sways excessively.
    If this tends to happen often, then you need to make sure the machine is properly balanced and not leaning too much to the back.
    Also the drum suspension rods do tend to wear out over time and loose their firmness, causing the drum to sway excessively. You can check this by opening the lid. Pushing down and from side to side onto the agitator, and seeing if their is a firm bound on the drum. Also making sure the drum returns to centre position. If the suspension springs feel loose and wayward, then they will need replacement.
    Regards
    Ash
    Nov 08, 2009 | Washing Machines
    MY DUET SPORTS DOES NOT DRAIN.
    your pump is probably plugged or the impeller on the pump motor is not turning properly and jamming.
    Sep 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Kenmore elite calypso waher
    The "PF" error code indicates a power failure to the dryer. To clear the error code, press Stop/Cancel.
    If the Stop/Cancel button does not clear the problem you will need to replace the control board on the dryer. The part number for the control board is 3976611, in case you need it.
    Ob code = out off balance
    cl code =
    If the door is securely closed & the CL error code appears, I would recommend checking the door lock switch & wiring harness to the door lock switch. Other possibility; control board.
    Dec 17, 2008 | Kenmore Elite HE4 Electric Dryer
    Testing Shows On Display
    press and hold start/cancel button for 5 secs. Thenpress on /offbutton and start/cancel together until Doff is displayed the machine should now be ok
    Nov 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
    Kenmore 22082
    OL on my washing machine
    May 17, 2008 | Kenmore 22062 Top Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    130 people viewed this question
    Sal De
    Gerry Harvey
    Gerry Harvey
