Question about Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 19" TV only displays blinking red light
My model LC19SB25U suddenly will not turn on. It displays a blinking red light in lower right had corner where normally there would be a green light. I have unplugged and replugged to no avail. Red light even blinks for a few seconds after unplugging. I do not have a copy of the owner's manual.
    Master:
  • 848 Answers
Hi
initially check fuses are good....if it is proper...... you are having problems with the power supply board .....you need to replace it ...it will cost you $250 to replace the board...
Posted on Feb 07, 2009
    Sergeant:
  • 326 Answers
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
  • 679 Answers
Will you try to reset your TV.
I cant get sony trinitron to turn on. the standby/timer red light blinks several times and it wont turn on what can i do i am bored without tv
Likely damage to main power supply-------try to see if there is a specific number of blinks then a pause and repeats like 7 blinks a pause and repeats---that is an error code if there---with it AND THE MODEL NUMBER OF THE TV I might be able or not to help.
May 25, 2012 | Televison & Video
I cannot get it to turn on. in the lower right
The flashing light indicates a failure with-in the tv, the amount of blinks will coincide with a particular fault scenario. Tell me how many times the light blinks and I can tell you the problem. However, the tv will need servicing from your local shop. This tv is too complex to walk you through fixing this problem with Philips plasma tvs.
Dec 28, 2009 | Philips 42PF7220A 42 in. Plasma Television
No picture
If model of your TV is LC19SB25U, TV powers up, TV has back light,but on picture or menu, The problem is the part called main unit.
Oct 14, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Sharp model lc19sb25u sound and no picture screen
Part called main unit failed and require replacement. part number duntke352fm02.
Oct 08, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Sharp 19" LCD blinking red light
Your tv needs servicing, it has developed some kind of circuit malfunction. You can send it too me for fast repairs and return. Or find a shop in your area.
e-mail me...
Feb 07, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Jul 31, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Red Blinking Power Light Sharp Aquos
What do three blinks of the power light mean on my Sharp Aquos LC-C5262U? I cannot power up my display.
Jul 13, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC-42D62U 42 in. LCD HDTV Logo
130 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
