Question about Vizio P50HDTV10A 50 in. Plasma HDTV
46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
My 46" LCD VIZIO wouldn't turn on this morning. Thought it was remote since the amber VIZIO lettering was lit. Tried to turn on TV using the side panel on the TV button, and nothing happend. Since front vizio sign is lit, power is getting to it, but the TV will not turn on. Any advice or suggestions would help. I just got the TV in Dec. I have a 50" Vizio. It just won't turn on all of a sudden.
    New Friend:
  • 56 Answers
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
Posted on Feb 16, 2009
Repairing lcd tv
If you wish to get some details; check the site linked here. Pull up older posts.
Jul 21, 2016 | Vizio Vf550m 55-inch Full Hd 1080p 120 Hz...
Vizio VL470M won't turn on
see this instruction: God bless you
  1. Check if the power cord has been properly connected to the power outlet.
  2. Check if the main power has been switched on.
    (DVD player's power supply transformer could be burned out)
3. test the power outlet wall see the diagram
4. do not use the r.control use the power button directly from TV.
Jul 20, 2013 | Vizio 47"" vl470m 1080p 120hz widescreen...
I tried turning my flat screen on this morning remote would not cut the tv on thought it was the batteries but put the batteries in another remote and it worked what could be wrong
Check the remote control for its infrared emission. Check this link and select the site 'Electro-help' for details. Detailed description is there, about how to check and repair a remote control. Pull up older posts.
Jul 11, 2012 | Vizio GV42L 42 in. LCD Television
Have vizio vw46lfhdtv10a won't turn on
The other expert here is right--main is not being turned on and either main board or power supply could be bad.
Apr 26, 2012 | Vizio VW46LFHDTV10A 46 in. LCD TV
I have a Vizio VT420M. When I turn it on by remote, or power button, the Vizio light changes from amber to white, but I get no picture at all OR sound. Do these symptoms sound like a bad power supply,
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 25, 2017 | Vizio VT420M LCD TV
My vizio e420vl turned itself off and won't turn back on. When i plug it in the vizio logo lights up amber but it won't do anything else.
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
May 29, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
I have a Vizio VW42LFHDTV10A -- The first time I
Please check for bad electrolytic capacitors on both main board & power supply, if there is any "pup-up" one, replace it (them).
Aug 15, 2017 | Vizio GV42L 42 in. LCD Television
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
Jan 30, 2009 | Vizio L32 32 in. LCD HDTV
Vizio in stand by (amber lights) mode on monitor
Does the remote have one power button for on/off .... or, does it have separate buttons ?
Jan 13, 2008 | Vizio Gallevia GV42LF 42 in. LCD...
Vizio P50HDTV10A 50 in. Plasma HDTV Logo
1,794 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
