Question about Kenmore Elite HE3 Steam 8674 Dryer
We are new to the Kenmore Elite HE3 8674 dryer and it won't run
I got in and try a "normal" auto cycle on the dryer after turning it on. I press and hold the Start button and the dryer just dings at me and will not start. What am I doing wrong?
  • Jeremy Reddick
    Jeremy Reddick May 11, 2010
    Is it gas or electric?
Our daugther in law came over, and she forcefully shut the door, and the dryer started working. We are going to have the Sears people to come out and make certain that this dryer is not damaged.
Posted on Feb 08, 2009
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
60932990 Kenmore ELITE won't dry!! It turns on just as normally as any other day. It will...
Most likely the element is burn out. Fairly easy to change
May 11, 2013 | Dryers
Maytag dryer epicz says "controls
controls locked
This feature allows you to lock your settings to prevent
unintended use of the dryer. You can also use the Control Locked
feature to prevent unintended cycle or option changes during
dryer operation.
To enable the Control Locked feature:
Press and hold AUTO DRY LEVEL for 3 seconds. Control Locked
glows and a single beep tone is heard. To unlock, press and hold
AUTO DRY LEVEL for 3 seconds. The indicator light turns off.
Jul 15, 2011 | Kenmore Elite HE4 Electric Dryer
How do i get the control lock button to turn off?
There is a button on the control panel with a marking under it that says "Press and hold for 3 seconds to lock/unlock control". Look for the said button then press and hold it for 3 seconds or until the control lock light turns off. The button is usually the Auto Dry Level button for Kenmore Elite dryers and the Drain/Spin button for Kenmore Elite Washer. Whirlpool Duet Washers and Dryers use the End of Cycle Button to lock and unlock the control.
Sometimes the problem is due to electronic glitch and unplugging the machine for at least 30 minutes may solve the problem. But if the control cannot be unlocked by pressing and holding the button specified above or by unplugging the machine, the control panel electronics may need to be replaced.
Dec 21, 2010 | Kenmore Elite HE4 Electric Dryer
I have a kennmore elite dryer and I was very happy with it. Today morning no dryer cycle starts though all other usual lights etc. turn on as normal. After choosing the dryer cycle when I press start it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Dec 17, 2010 | Kenmore Dryers
Kenmore elite he4 quiet pak 9 dryer display code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 15, 2010 | Kenmore Elite HE4 Electric Dryer
2 problems with my Kenmore Elite dryer
Hello, I would be curious to know if the dryer performs the same way on "timed" dry and "auto-dry", have you tried ? Here's a tip on how you can absolutely know if you have venting issues ( and I don't necessarily mean a "clogged" vent, there are other factors too ) Disconnect the vent at the rear of the dryer and run a cycle as you normally would and observe what happens. Also if it has the flex venting on it ( whether plastic or foil type ) get rid of it, personally I will not even service a customers dryer until they agree to change it when present. I'll watch for you reply in this post if I can assist you further. Good luck. macmarkus :)
Apr 10, 2010 | Kenmore Elite HE4 Electric Dryer
Model # 11061082000 electric dryer....elite kenmore
you can't get any parts for this dryer the computer board is no longer available,must be old technology replace it.
Dec 28, 2017 | Kenmore Elite HE4 Electric Dryer
Dryer turns on, but does not run
Try to turn the drum inside with no clothes in it, does it turn freely both ways?
Then as someone is holding the start button, hold the door switch button, then try to turn the drum counter-clock wise, and see if it will start turning on its own.
If it does start turning, then the motor is more than likely the problem.
If it dosen't then the timer is more than likely the problem.
Feb 05, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3 Steam 8674 Dryer Logo
246 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
