Question about Whirlpool Duet GHW9150P Front Load Washer
Washer will not fill with water or wash
Replaced micro computer machine control and still have same problem.
    Problem Solver:
  • 17 Answers
LID SWITCH NO GOOD
Posted on Feb 08, 2009
Water still running when machine is off, what to check for
Here is what you can do to determine what part you will need to replace. Turn the washer on and let it fill with water on any wash cycle. While it is filling with water unplug the washer (power cord to the outlet). If water continues to enter the washing machine it means that the washer inlet valve will need to be replaced. If the water stops filling when the washer is unplugged then you will need to replace the timer or control board which powers the valve.
Oct 23, 2016 | Washing Machines
Crosley washer model caw9244xq2. Started normally, ended on spin, now it's full of water and won't start. I have to hold the start button for it to turn on, then nothing. Help?!
there is a micro switch in the knob of the machine that not telling the washer machine to empty the water, you need to call a repair person, or buy the part your self and buy a manual and do it yourself.
or
www.youtube.com/how to replace wash machine control knob
www.infolinks.com/replace defective washer machine knob
www.ask.com/how to replace washing machine control knob
Apr 21, 2015 | Crosley Washing Machines
F26 errorcode on whirlpoolduet sport. washer will not start filling. the door locks and nothing happens
Have you checked the drain filter? One of the things that could be causing this is the water level sensor. If the drain is plugged then the machine thinks there is water in it. If you take the front panel under the door off, there is a big knob that unscrews, be ready for lots of water though! There is also a filter there that catches things before they get to the pump.
Apr 07, 2014 | Whirlpool Washing Machines
I have a 6 year old Frigidaire washing machine. It does not fill with water. All water lines have been checked and are okay. Washer goes immediately into the wash cycle without filling with water.
This is symptomatic of a malfunctioning water control valve- the hot water one if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call to confirm that it is not something else like the control board or connectors ;-0(
Good luck,
John C
Mar 29, 2011 | Washing Machines
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Washing machine fills with water but will not go on to the wash cycle . The machine just fills with water and stops. Have to bail out the water by hand.
Your lid switch needs to be reset or replaced. Open the control console to access the lid switch. Check the fuse for continuity. Check the alignment of the lid switch for contact with the micro switch.
If these cannot be reset they must be replaced.
Oct 08, 2009 | Maytag Washing Machines
1999 maytag neptune washer stops after filling up with water
There are a couple of common causes for a problem like this. First is a bad door lock assembly that also damages the machine control board (in the control panel). If this is the case the R11 resistor on the machine control board will be burnt.
Maytag has identified seven resistors that relate to specific components that need to be checked or replaced if the resistor is damaged. Listed here are the resistor identification, the circuit involved, and the recommendation:
R9 / pressure switch / check for loose connections or high resistance on switch contacts; replace pressure switch if necessary.
R11 / door lock wax motor / replace door lock mechanism and machine control board.
R51 / hot water valve solenoid / replace water valve and machine control board.
R52 / timer motor / check for loose relay terminal connections and replace machine control board.
R53 / cold water valve solenoid / replace water valve and machine control board.
R143 / (-) 24 Volt DC / contact was made between neutral and the 24 Volt DC circuit.
R162 / electrical buffer circuit / wire harness and machine control board.
Another common issue is a slow water fill fault. If the washer does not fill within a certain time the control will stop on a fault. Usually when this happens the START button can be pushed to continue the cycle.
Washing machines that won't fill or fill slowly often have a restriction in the incoming water supply -- usually in the screens of the inlet hose washers or the water inlet valve itself. Remove the hoses to inspect this condition. If the water inlet valve screens are plugged, replace the water inlet valve.
Go here for: Maytag Neptune Washer Parts
RepairClinic.com
Appliance parts, help & more
Apr 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Filling up won't stop
hi. thanks for the question .if the water would only shut off ,by turning off the water .replace the water valve thanks the appliance doc
Sep 28, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Filling With Water
"preesure switch" built into controller, remove 2 screws behind console nad check the clear hose hasnt become diconnected, or perhaps has a crack in it not able to "read" water level
Mar 04, 2008 | Fisher and Paykel GWL11 Top Load Washer
Amana washer has no hot water - cold works fine
There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
Dec 04, 2007 | Amana ALW880WH Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
15 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
