Question about Whirlpool LER3624JQ Electric Dryer
My dryer won't start
Checked the outlet, has good ventilation, and has no obvious electical problems. can you help?
  • hilldog4534 Feb 09, 2009
    Great advice, thanks alot for the help. You FIXYA my dryer. It's appreciated.
  • mmercado_48 Mar 04, 2009
    wont start
  • Whirlpool Master
  • 8,220 Answers
Probably a lint blockage of some sort. To prevent fires the manufacturer of this dryer places numerous safe guards to prevent fires. If the dryer does not rub at all then you need to replace the fuse. You also need to clean the dryer lint out or you will just be buying fuses. The fuse looks like this:
my dryer won't start - 52f663d.jpgb4c1945.jpgLocation is in the rear on the blower housing.
Posted on Feb 07, 2009
  • Dan Webster
    Dan Webster Feb 07, 2009
    FUSE LOCATION
    Post your model number to any of these fine forums for
    a simple answer that will save you lots of money:
    http://appliancejunk.com/forums/index.ph...
    http://forum.appliancepartspros.com/
    http://applianceguru.com/
Whirlpool duet dryer, no lights on panel...
check both breakers one may be bad if its a220dryer
Jul 24, 2013 | Dryers
Have power everywhere but won't turn on
see this causes and fix it. God bless you
1. No power to the dryer
Make sure there's power getting to the dryer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Door switch / Door switch actuator lever
The dryer would not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Oct 02, 2012 | Dryers
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
I have whirlpool electric cloth dryer Model # LEC7848DZ1. Serial # MF0902194 I doesn't start at all. no heat no spinning. Please help. electic durrent is up to outlet, so electicity is not a proble....
Its possible that the thermal fuse is bad and needs replacing. Could have been caused by partial plugged hose to include where it hooks up. When it senses that its too hot it will blow that fuse. Hope this helped.
Mar 15, 2009 | Whirlpool Dryers
Dryer won't start.
Check the dryer door switch and the thermal fuse.
Mar 15, 2009 | Maytag Dryers
Dryer not hot enough
If you have tried all of that then the only other thing it could be is a ventilation problem. Try checking for any obvious clogs of lint in the vent line at the dryer or side of the house where air exits. If no obvious issues then attach an electric leaf blower to the dryer side of the vent and let blow for 5 min. This should break loose any lint in between and you will see the results at the end of the line on the ground. If your vent is really long and you still cant get it all out then you may have to consider replacing the vent hose.. Hope this helps.. Thanks
Feb 18, 2009 | Amana LEA11 Dryer
Kenmore elite dryer
You wouldn't be trying to **** up to the Guru now, would you? :o)
I have a couple of links for you to look at to see if this can shed some light on your problem.
If your dryer is running, but not heating refer to this link:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If your dryer is not running at all, this link goes into a little more depth about dryer problems and how to diagnose the symptoms:
http://www.fixya.com/support/r385301-thorough_dryer_advice
The first thing you need to do is figure out the symptoms. Keep in mind, the motor operates off 110-120VAC. The heating circuits require 220-240VAC to operate. If you are missing one leg of the 220VAC service at the outlet, the dryer will run, but the heating circuits will not work - double check your outlet first. If your dryer has been running extremely hot, and if you are experiencing longer dry times, you have a ventilation problem you need to resolve. Extremely long ventilation ducting, runs with a lot of bends, or ventilation that runs through an attic or crawl space, can contribute to heating efficiency problems. I would suspect you have a blown thermal fuse (located on the air blower housing - white plastic in color). You will need to remove the lower panel under the door to see it.
If you get confused, please post back and let me know. I hope this helps you.
Jul 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer not working
there are some switches that have to be closed before the hit start WILL FUNCTION. Most obvious is the door switch. a thermal overload in the motor circuit may have opened preventing power getting to the motor. check the overload in the blower housing. just jump it out with a piece of wire [temporarily] if it starts, replace the overload.
Sep 12, 2007 | Dryers
Whirlpool LER3624JQ Electric Dryer Logo
141 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
