Question about Fantom Vacums Cyclone XT Upright Vacuum
The brush status indicator
My Fantom Cyclone XT is now 10 years old. The brush status light goes from green to nothing and/or red and back to green. This happened on and off 6 years ago but had quit until now. It is always clean as as a whistle, nothing clogged anywhere or in the brush. Any ideas where I should go from here? Thanks!
  • 22 Answers
Try the brush belt condition
Posted on Feb 09, 2009
Fantom F11063 Cyclone Vaccum
I think the manual can help you in replugging the wires
How did you pull out the wires from circuit board ?
Is it with professional help or through some other means
Sep 18, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Replace belt on fantom cyclone vacuum? the manual does not decribe replacing the roller belt - i can't get it open to expose the belt
On my 10-year-old model, the two screws securing the cover are under the two llight bulbs. Pry off the clear plastic covers, take out the bulbs and screws, and the cover lifts off.
Dec 01, 2009 | Fantom Vacums Cyclone XT Upright Vacuum
How do i replace the belt in the Fantom Cyclone XT vacuum
remove the covers over the headlights and under the shiny foul. there are two screws. there are two tabs that hold down the cover over the wheels, they just pop on/off with a click.
on my xt. i had to remove the rolling brush and clean out all the hair that was stuck in the bearings. remove the screw holding down the motor and belt. pry out the roller brush to get to the bearings. there was some serious hair ball in there.
reassembled mine and it works perfectly now :)
Dec 19, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom Cyclone XT Vacuum Cleaner
Here is the owners manual which goes over some troubleshooting problems.
http://www.fantom.com/fantom/manuals/Cyclone.pdf
At first I would think it was the thermal overload, which is covered in the manual. But I would guess that you have let it sit for 30 minutes to cool down and tried again and the vacuum still didn't work.
I would think you may have one of four problems.
1. Your thermal overload was tripped and is stuck and will need replaced.
2. You have a clog in your vacuum lines or the brush roller is froze, which keeps causing the thermal overload to trip.
3. Your power cord has a short, which would need replaced.
4. Your power switch is bad, which would need replaced.
Out of these 4 possible problems I would say the only one you could fix on your own would be problem #2. Make sure the vacuum is unplugged and take the brush roller off and clean it, make sure it moves free. Check your vacuum lines to make sure you do not have a clog, other wise the motor does not get air flow to cool it down causing the thermal overload to trip. As for problem 1, 3, and 4 I would suggest taking it to a repair shop.
Hope this helps, post back.
Jul 11, 2008 | Fantom Vacums XT450K Upright Vacuum
Fantom Cyclone wiring
The only sure way recommended (and probably the safest) would beto get a service manual or at least a schematic diagram. The FantomCyclone XT was originally manufactured by Fantom Technologies, Inc.that closed in October 2001. The replacement for a Fantom Cyclone XTwould be Westinghouse Wired Deluxe Edition (either a WST1550 or a WST1551). These replacement products are now handled by Salton Inc. Perhaps you may inquire from them:
  • Salton Inc.
  • 1 800 616 8689
  • salton@saltonusa.com
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Jun 08, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom cyclone belt status light
The belt may have stretched to the point that it won't turn the brush roll, you might try a new belt and hope that fixes it. Parts for these older Fathoms are scarce and are obsolete.
Apr 22, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Circuit board
You should be able to locate parts for your vacum at this link by entering the model number.
http://www.fantom.com/fantom/default.aspx
Mar 25, 2008 | Fantom Vacums Cyclone XT Upright Vacuum
Fantom Vacums Cyclone XT Upright Vacuum Logo
192 people viewed this question
Top Fantom Vacums Vacuums Experts
Richard Agent
Charles T Nevin
Charles T Nevin
Are you a Fantom Vacums Vacuum Expert? Answer questions, earn points and help others
