Question about Canon PIXMA MP780 All-In-One InkJet Printer
WRONG CARTRIDGE and Printhead does not move MP780
I have a wrong cartridge error. However, I cannot access the printhead since it does not move when I open the cover. The printhead remains stucked in the right corner. BTY, I'm not using OEM cartidges, just cheaper replacements. Any suggestion will be appreciated.
  • Manny Imson Feb 12, 2009
    Thanks for your input Frank. I tried moving the printhead while it's off (both plugged and unplugged) and did not move. I did not want to force it more since I've given a good force on it that I may damage something. I also tried pressing the sensor on the right side and did not work either. Thanks
  • Anonymous Mar 09, 2009
    I have the same problem "Wrong Cartridge" display. I have checked all the cartriges they are fine, i have turned it off and on again, still not success. can anyone give me any other advise.
    thanks deb
  • 191 Answers
Your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
Posted on Feb 08, 2009
  • Frank Zhang
    Frank Zhang Feb 10, 2009
    any help for you please send a feedback thanks
  • Frank Zhang
    Frank Zhang Feb 12, 2009
    printhead seat at parking lot, there is a pump cap which will go down when power on (you can see from opened righe cover), there are three situation: 1) you can see the pump cap go down then printhead can moving to left itself (this is normal case) 2) you can see the pump cap go down but printhead can not moving itself 3) you can see the pump cap can not go down and no any printhead moving itself .
    you may try
    1) to moving printhead when 2) is occured, and check printhead drive bell and motor gear works status.
    2) check pump cap moving drive if 3) is occured. (pump locked the printhead you can not moving anyway)
    is this helpful feedback please.
I have just changed all my cartridges and they are genuine Canon ones. I am getting WRONG CARTRIDGE message on my printer. Please help. thank you
Hi!
The printer reads the printhead as a cartridge too and the error is referring to the printhead that's faulty and needs replacement!It is an expensive part but can be replaced!Contact your local canon dealer and ask them for a quote on the printhead!
Good Luck!
Apr 01, 2011 | Canon PIXMA MP780 All-In-One InkJet...
Will not print-keeps coming up with "wrong cartridge"
Wrong cartridge on a Canon means the printhead is bad, not the inks. You need a new printhead
# QY6-0049-000
Jan 09, 2010 | Canon PIXMA MP780 All-In-One InkJet...
PIXMA MP780 "WRONG CARTRIDGE" MESSAGE?
Turn off the printer, and unplug the power cord. Remove the cartridges, then the printhead unit, clean the printhead in look warm water GENTLY. Dry completely, clean the contacts with an eraser GENTLY. wipe contacts with tissue, then re-install back into the printer, add the cartridges, so an alignment and a clean, then print.
Jan 05, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Got "wrong cartridge" error while attempting to print. Removed & reset all ink cartridges, still same error. Removed inks & print head, immediately lost power. Unplugged, waited, put everything...
It's a bad printhead, when it is removed, power should come back, but you need a new printhead. Wrong cartridge means the printhead is bad.
QY6-0049-000
Nov 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon Pixma MP780
You get that message when the printhead goes bad. It's not the ink cartridges. You need a new printhead
# QY6-0049-000 around $60.00
Nov 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
"Wrong cartridge" error when in fact it is the right cartridge
On this machine it means the printhead is bad. QY6-0049-000 around $40.00
Jul 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Wrong cartridge message always on
Wrong cartridge means you need a new printhead. qy6-0049-000. Around $59.00. Cartridge in this case refers to printhead, not ink cartridges.
Jun 19, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Mp780 wrong cartridge error
Try to reset to factory .
Remove ink cartridges and print head.
Power off machine and unplug for 10-15 minutes.
Restart machine and install head and cartridges.
Jun 13, 2009 | Canon PIXMA MP780 All-In-One InkJet...
How do I remove printhead?
same as when you change ink tanks...
1.follow the same procedure you use to change ink tanks/cartridges to remove the current ink tanks
2.remove all ink tanks/cartridges
3.the printhead is what the ink tanks/cartridges sit in, the furthest half of the part the ink tanks/cartridges sit on is the removable part/printhead, it is loose so you can simply reach in and carefully pull it out.
Easy as 123 ...
eSid
Mar 16, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Receiving message stating "wrong cartridge"
Overnight I started getting the "wrong cartridge" message on my Canon MP780. I use only OEM cartridges. As the Canon website suggested, I replaced the printhead with a new one (Empire Office Machines for $48.25 plus shipping) and it works great. Prints better than ever. Easy fix for my machine. I did read that using refills can cause more problems than just the printhead.
Oct 14, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA MP780 All-In-One InkJet Printer Logo
672 people viewed this question
old marine
old marine
