Question about Olympus FE-170 Digital Camera
Camera powers on, screen turns blue then turns off.
Dropped camera, it starts up OK but then closes down leaving lens out.
By pressing green arrow button the lens goes in closes. However images on the memory card then come up on screen. Can also use the menu & guide without problem.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Based of your description, the fault is entirely on the lens assembly/gear /mechanical system. The camera can not sense the status of the lens and reverts to default view condition. It maybe that the lens is not fully extending and/or not returning completely on its rest position. Normal course of action would be to seek the services of an authorized service center as this involve intricate mechanism and timing sequence.
Alternately, you can try:
  • clean the battery contacts of the camera. In some instances, it may even be necessary to scrape them to expose fresh metal;
  • bend (stretch) these contacts to ensure that they present enough pressure to the batteries. This is to ensure that the camera gets full power from the batteries;
  • if allowable, replace the batteries with alkaline high capacity instead of rechargeable ones;
  • if still a no go, you may need to "jar" the lens back into action. This involves thumping the bottom of the camera against the palm of your hand. The idea is to force into alignment any possible dislodged gear when it was dropped.
Good luck and thank you for using FixYa.
Posted on Feb 11, 2009
  • 153 Answers
May be the spring inside may be loosened
Posted on Feb 08, 2009
  • nicra7 Feb 08, 2009
    try correcting it then it wil be allright
  • 679 Answers
Remove the battery and reinsert after 1 minut.
    Brigadier General:
  • 3,614 Answers
What is exact model of the cam you have>
    Master:
  • 848 Answers
Hi
lens is stuck ...... the sensor is damaged..........you need to take to repair shop to get it repaired ......
Hello, i have a sony cybershot DSC-S650. Expert, my problem is that when i turn my Sony Cybershot on the lens won't look at nothing, it's ust a blackscreen. Can you please help me. Thank you, My...
Make sure that the batteries in the camera are good and turn it on. Is there a light that comes on to let you know that the camera has power and is ready when you press the power button? Does that light come on and what color is it?
If the light ends up green, then you know the batteries are good and the camera is functioning properly and is ready to take a picture. If this is the case, then after you turn it on - look on the back of the camera for the focus zoom in and out buttons. Sometimes they look like a switch that you can rock right or left. Press the switch and look through the lens. Does press the switch or arrows in either direction clear up your view and allow you to see anything? Are you looking through the lens hole or are you using a small screen to view on the back of the camera? If you are looking at a screen on the back of the camera and that screen is black - it means that you dont have the exterior view option turned on in the cameras settings. Sometimes there is a button labeled "view" on the back of the camera to alternate from the exterior view screen on the back of the camera and using the lens hole view at the top. Press that key to make the view screen turn on. If this option is not turned on yet, press the menu key on the camera and use the arrow keys to scroll through the option choices until you find the image preview choices and turn this option on. Then save this choice and close the menu features to see if it comes on.
If you are not getting a power indicator light when you turn the camera on, then replace the batteries. If the light comes on and its something other then green and steady - (like red and flashing) check your camera manual to see what this indicator means. Some cameras show a red light that is flashing when you turn them on to indicate that the memory card is full. Some camera have a red light that is steady to indicate that the battiers are almost out of power and they will show a picture on the digital to indicate how much power you have left before they shut down. Each model camera is different according to the options it came with.
Jul 06, 2011 | Sony Cyber-shot DSC-W80 Digital Camera
Tip
Troubleshoot Non-Retracting Lens Due to Camera Drop
<span>Remove the batteries from your digital camera and leave them out for a few minutes. If you are using rechargeable batteries, make sure the batteries have a full charge before placing them back into the digital camera. It is recommended that you charge the batteries for at least 6 hours. If you are using regular AA or AAA batteries, make sure you are using brand new batteries of the same brand. Turn the camera back on to see if the lens will retract. If that doesn't work, turn the camera back off and try turning it back on while you are pressing the function or OK button.<br />If the batteries were low when the camera was dropped, the lens may not retract properly until the camera is reset. Remove the memory card from your digital camera and install new batteries. Do not put the memory card back into the digital camera and turn the digital camera back on. You will get an error message regarding the memory card, but that is okay. With some digital cameras, leaving the memory card out will trigger a reset within the digital camera.<br /></span><span>If you have an audio/video cable (AV), insert that cable into the digital camera and turn it on. By using an AV cable, the LCD screen will not power on, which means there will be more battery power available to the digital camera. If any dirt got into the digital camera when you dropped it, the extra power may help the camera retract the lens.</span> <span>Place your digital camera on its back on a hard surface. The lens should be pointed towards the ceiling. While pressing the shutter button, turn the digital camera on. The idea behind this concept is that the camera will try to autofocus, which may help seat the lens barrel pins back into their slot.<br /><b><br /></b><br />It is possible that when you dropped your digital camera, dirt, sand particles, etc. may have lodged themselves into the lens barrel. Gently blow around the lens barrel to knock lose any particles. Using a microfiber cloth, wipe off the lens and try to wipe as deep into the lens barrel as you can. You can also try using compressed air and blowing it in the gaps around the lens barrel. Be careful not to blow any of the compressed air onto the lens itself, as the pressure of the air may damage your lens. The idea here is that if there are any particles lodged in the lens barrel by the lens mechanism, you will be able to knock them lose.<br /></span>
on Jun 29, 2011 | Cameras
Lens error lens wont close what to do?
Hi,The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Here are different solutions to this problem;
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra power to help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins back into their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one). Some people also have actually used a "Shop Vac" with this fix to help extend a retracted lens.
Thanks and take care
Apr 25, 2010 | Nikon COOLPIX L18 Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Camera will not turn on sucessfully. Says "Turn Off and On Again"
This is not an elegant solution, but it seems to be working. (I might have read some one else mentioning it for another brand of Samsung camera). I hit the end of the camera where the attachment to the computer gets plugged in against the palm of my hand pretty hard about 6 times. Then I tried it and it worked! There is some logic there since it started having the problem right after I put it down on a soft surface from about three feet.(Ididn't really drop it, but tossed it there - gently, I thought - because my hands were full and I was starting to lose everything). In the future I will treat the camera a little more gently knowing that mechanism is somewhat easily knocked out of adjustment.
Mar 26, 2009 | Samsung L77 Digital Camera
At power on, lens comes out then goes in/out tehn told to restart
intialize camera first. press the playback or review button while camera is turned off. then go to menu, go right to setup, press right arrow on setup, go down to setup1, press right arrow, highlight initialize, press right arrow, select ok with the middle button. if this does not work, try removing battery for 30 seconds then reinsert it. if these steps would not resolve issue then camera needs service. www.sony.com/repair.
Mar 19, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
How do I set the time on an Olympus c-725 Camera?
Set the mode dial to AUTO, then press
the POWER switch to turn on the
camera.
● Be sure to take off the lens cap before
you turn the camera on (P. 27).
2 Press OK button.
● The top menu is displayed.
3 Press the up arrow button to select the clock.
4 Press
to select the date format.
● Select any one of the following formats:
D-M-Y (Day/Month/Year)
M-D-Y (Month/Day/Year)
Y-M-D (Year/Month/Day)
● This step and the following steps show the
procedure used when the date and time
settings are set to Y-M-D.
Press right arrow button move to the year (Y) setting.
6 Press
up or down arrow to set the year. When the year is set, press right arrow to move to the month (M) setting.
● Repeat this procedure until the date and time are completely set.
● To move back to the previous setting, press left arrow.
7 PressOk .
● For a more accurate setting, don't press until the clock hits 00 seconds. The
clock starts when you press the button.
8 To turn the camera off, press the POWER switch.
● The lens retracts.
Jan 06, 2009 | Olympus Camedia C-725 Digital Camera
HELP! dropped camera, lens won't go back in, shutter won't close
$100 is hardly expensive, and at that cost it would be cheaper to replace it than have it repaired. In future, keep it on the neck strap.
Mar 15, 2017 | Cameras
Tapp the lense GENTLY in the opposite direction of the misalignment
Nov 25, 2007 | Kodak EasyShare DX6490 Digital Camera
Olympus FE-170 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
