Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
HORRID NOISE I have took it all apart and thoroughly cleaned it. It is still picking up dirt etc. But the noise sounds like its taking off. It is not that old so can not be the engine my mother has one that she has had much longer and is fine she has also checked it it is out of guarantee but is working the noise is terrible. Can you help???
  • 134 Answers
Hi
take out the belt and brush. Switch on. If the noise has gone you know its the brush.
Posted on Feb 14, 2009
I have a DC41. The power head wont turn and is making a squealing noise.
Sounds like your power head is seized or almost seized. Possibly real dirty. take apart and lubricate ends and replace the belt I feel is slipping Hence the squealing.. Clean all parts thoroughly.
Dec 02, 2016 | Dyson DC41
I have a Dyson I took out the screws to clean it before I opened the canister now I can not get it together again
You're a bit unclear on what screws you took apart to 'clean it'. If you took the canister apart, then this Snapguide page
How to Clean Dyson DC07 Canister goes through taking the top section thoroughly apart, and has some notes about things needing to line back up properly, which might help in the event that you're not getting things to snap back together right. I took mine apart solo after picking it up cheap at a flea market, and also recall reassembling the top took a little patience.
Good Luck!
Oct 30, 2015 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Took apart my electrolux 6500 sr. How do I get my fan shroud off to clean the blades? Thank you.
Oops. Don't. First blow it out with another canister vacuum or air hose. That's usually sufficient for removing dirt and dust. For dust/dirt in the motor, use a motor cleaning spray that can be picked up at most auto parts stores. One that evaporates quickly and doesn't leave a sticky residue. One's called Electric Motor Contact Cleaner by Gunk (http://www.gunk.com/CAT_NM1.asp). There are others.
Hobby shops may also have one available called Dynamite Magnum Force 2 Motor Spray.
It shouldn't be that dirty unless someone has been using generic "made to fit" Electrolux bags. Or if water or other liquid has been vacuumed, resulting in rust, etc.
Keep in mind that reassembling the vacuum is more difficult than taking it apart. If not done so correctly, various problems may result. While you have it apart, it would probably be a good idea to use pipe cleaners to clean out the tubes connectiong the "control valve assembly" to other parts of the vacuum. Also, unscrew the knob at the top of the "cva" to check for wear and breaks. Clean dust thoroughly from all interior parts.
Oct 05, 2010 | Electrolux Epic 6500 Vacuum
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Not picking up anything as well as it used to.
try putting new filters in, and check the hose for blockages,
Iain
Dec 23, 2008 | Eureka Capture Upright Vacuum Vacuum
Hoover Dirt Finder (light) not working
Good be a bad sensor, but if less then a year old, it is under warranty. I would take it in to a warranty repair shop and have them fix it.
May 10, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Ny Panasonic MC-E4013 has lots of ****, but the brushes don't pick up from the carpet. The drive belts are not broken and the brush roller goes round OK.
Usually, shen you have this problem, there is an obstruction of dirt etc. somewhere in the suction path.
You need to take the vacuum apart and clean thoroughly first.
Then get back to me.
Mar 21, 2008 | Vacuums
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
244 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
