Question about Soyo SY-7VCA-E Motherboard
Powersw hddsw and other connector in soyo-7vca mother board
Hello,I change my tower but i dont see where de pin connectors go. My question is do you have a plan or indication to connect at the right place
thank
and excuse my english .
    Problem Solver:
  • 16 Answers
You need the motherboard manual. I have found your one on the link below, you will find detailed instruction on pages 30-32 of the manual.
The manual is 5mb in size so it might take a few seconds to download, it is a PDF file which means you will need Adobe Reader to see it.
Good luck and hope this helps (click on link)
http://www.soyo.com/uploads/downloads/manuals/686/m7vca10.pdf
cheers
Bri
Posted on Feb 07, 2009
Msi g41m-p26 won start (no power)
The most likely solution is to replace any Capacitors that have blown in the onboard power circuit. Look for a Capacitor that has got a very bulging top in the region of the power connector.
Dec 05, 2012 | Computers & Internet
Need a new power supply for a soyo mother board Crown model fp-
All you need to know is if your motherboard has a 24-pin or 20-pin power connector. You can just count the pins if you don't know. There connector is located on the motherboard. It looks like this: moondogwst75_3.jpg
So if it's a 24-pin, order a 24-pin power supply. If it's 20-pin, order 20-pin. Hope this helps!
Aug 28, 2011 | Computers & Internet
Hp D 530 - DK907T 902-FAN COMMAND 2 PIN CONNECTOR FROM POWER SUPPLY NOT CONNECTED NB i've changed the chassis it was SFF ans i 've changed in Tower with a standard power supply
Maybe you put the wrong jumper of the power jumper for the front panel.
Explanation:
You can see the switch to turn on the PC right, then make sure that switch correctly installed on the right jumper on the board. Follow the cable to attach to the mother board.
Aug 22, 2011 | HP Compaq Business Desktop d330 Slim Tower
Not audio from de front , went i plug audifon fron the fron theres no audio
That's cause the front audio connectors are not connected.. To do this open up the tower.. Now locate the wires from the front connector.. Its labled j audio.. Now on the main board there is a jack for it,, some pins labled audio as well if its not labled then look for the pins in the same fashion of the jack.. If u see some plastic jumpers bridiging 2 pins remove it.. Plug in your front audio connector.. That's it your done..
Aug 03, 2010 | HP Compaq Presario SR1820NX (ER919AA) PC...
Need 7vem pro manual to install mother connector.
look closely at the board most soyo boards have a pinout legend on the board it will be in white lettering, if not try the soyo homepage, or call there tech support they can more then likely email you a legend
Jan 18, 2010 | Soyo Computers & Internet
Where to plug in powersw reset sw and hddled at the board
Try this link to a picture of the front panel header for your board.
Jan 10, 2010 | ASUS P5GC-MX/1333 Motherboard
Wiring off the tower
The 2 grey wires with the 4 pin connectors would be for the USB ports at the front of the tower. They need to be connected to the motherboard usb pin outs. Usually marked on motherboard as "USB1", "USB2" etc. Generally the red wire should be the "power" and goes to pin1 or 2 on the connector. Pin 1 is normally marked by a thick line on the board at that end of the connector, but it's easier to say Pin1 is the opposite end to the single pin on it's own (which isnt used). You really should check the manual for the board to confirm the connections though.
Jan 03, 2009 | ASUS P4P800 SE (890552603657) Motherboard
I need the manual for a soyo sy-kt400 dragon lite motherboard
Hi freebird2k6,
Go to this Soyo link:
http://www.soyousa.com/content/Downloads/155/&c=35&p=173&l=English
Drivers, bios & manual located on this site.
Manual is at the bottom of page. (Soyo no longer supports the board so download everything & burn it to CD).
Soyo may stop listing these drivers soon.
Mike
Dec 31, 2008 | Soyo SY-KT400D DRAGON Lite Motherboard
Pluging in extra usb ports/Mic and headphone jacks from the tower
Answer me this. You're case is an Antec tower? The motherboard is the Asus P4P800 SE ? Is this correct?
If you have you're manual you can see what goes where on the board for front panel connector page. 2-31. (This diagram shows you how to connect the front mic & speaker).
To connect the Antec's front USB ports plug the case USB front connectors onto USB56 & USB78 shown on page. 2-30. Most case wires are already set within their USB connectors & the Antec's front USB connector should fit right on the mother board's pin's. If you need you're user manual, download from Asus by clicking on this link. http://support.asus.com/download/download.aspx?modelname=P4P800%20SE&SLanguage=en-us
Good Luck!
Mike
May 19, 2008 | ASUS P4P800SE Motherboard
Soyo SY-7VCA-E Motherboard Logo
91 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
