Question about Kenmore HE2 Plus Front Load Washer
Weird rubbing or mild grinding noise when in spin cycle.
Kenmore HE2 front load washer makes a weird rubbing or mild grinding noise when in spin cycle. Seems to be worse with larger loads. This just started happening. Any suggestions?
Matt
    Scholar:
  • 31 Answers
It sounds like the bearings on your tub are going. This is an expensive and difficult job to do. (approx $450 parts and labour and you may do more damage trying to take it apart)
Posted on Feb 12, 2009
I have the same problem
Posted on Feb 11, 2009
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
TOO MUCH NOISE WHEN FINAL SPIN CYCLE
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 10, 2011 | Kenmore HE2 Plus Front Load Washer
My 7 year old he3 has a terible thumping noise when in the very fast spin cycle it is like the tub is coming out. The spin cycle before last is not as bad. the shock absorber are ok I can take the front of...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
heatman101
Feb 11, 2011 | Kenmore HE2 Plus Front Load Washer
Loud shaking in the spin cycle
Washer Problems
heatman101
Jan 19, 2011 | Kenmore HE2 Plus Front Load Washer
Once it goes to the last spin cycle ,( the fastest one) it starts making a thumping sound . could it be a belt or bearing?
Washer Problems
heatman101
Jan 13, 2011 | Kenmore HE2 Plus Front Load Washer
Our washer isn't able to progress from the rinse cycle to the spin cycle. It makes a grinding type of noise, and then all the lights blink on. What I've been doing is turning the machine off and putting it...
It is taking too long to drain, most likely because the drain pump rotor has become detatched from the shaft. It could also have something stuck in it and rubbing on the rotor blades causing this sound. I recomend first acsessing the drain pump by removing the bottom front panel and unscrewing the front of the pump. Be careful because you will have water pour out the second you unscrew it, so grab some towels. If there is some obstructions in the pump, remove them and test it. If it does not work, replace the pump. Hope this helps you:)
Nov 27, 2010 | Kenmore HE2 Plus Front Load Washer
My Whirlpool washing machine AWM6100 is weird. it washes no problems but when it comes time to drain there is an awful noise any idea? it does drain and spin its just the noise
you may have something stuck in the drain pump that is rubbing or grinding on the impellar wheel
check for any obstruction in the drain pump and the hoses that led in and out of the drain pump.if you do not find anything then you may need to replace the drain pump. as long as this noise only happens in the drain cycle.
Feb 09, 2010 | Whirlpool AWM6100 Front Load Washer
My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
When in spin made loud klunking and screaching noise. now will not work in spin cycle without making loud klunking noise
Pull off the bottom panel, (three 1/4" screws along bottom). Check for chunks of concrete hanging down, or in the bottom pan. I have seen the lower front counter-weights on the HE2 break off several times. If not, reach in and give the basket a hard spin by hand, if you hear clunking or grinding, or the basket feels loose, you have a bad basket brace (usually caused by slop in the rear bearing). You would need to replace the rear shell (comes with a pre-installed bearing) and the basket. Depending on age, these parts may be in warranty, check your manual.
Apr 20, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
1,008 people viewed this question
Fordexpert
Archaeology
Archaeology
2mikecurtis
