Back to:
Tags:
Hawking PN9249 Router
What do the router lights mean?
By Bomber - usenet poster
I have a Hawking 4 port router- PN9249. I can't find a manual
online anywhere & I seem to have lost mine.
There are 2 rows of 5 lights across the front.[WAN & 4 Ports] They
appear to be labeled on the left side-- but the labels don't help me.
Top row- Link/activity
Bottom Row- 10/100
What does the 10/100 light indicate? One of mine is out & it goes
to the computer that is acting up on my LAN. [It can't even ping
anyone else though it sees one other computer and can be pinged from
yet another.]
I spent a few days trying to get the reprobate working before I
noticed the router light. Changing the cable to another link moves
the 'off' light to that link.
Hopefully knowing what it means will help me diagnose the problem.
[2of the computers on my LAN are W98SE & it is one of them that I'm
having trouble with. Comparing the ipconfig results between the 2 -
the only thing different is the NIC & its physical address.]
Thanks,
Jim
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Beresford
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Toss the cable in the garbage and replace it with a brand new one. Ta-da,
problem solved.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on What do the router lights mean?:
I don't want to Accept this solution
Solution #2
Not Rated (0)
2Pansy
Rating: 0%, 0 votes
You probably have a bad cable.
The e-mail address in our reply-to line is reversed in an attempt to
minimize spam. Our true address is of the form
Thank You!
Can you Help with these Routers problems?
Routers
have 1 laptop and wan to use wireless
Routers
attempting to connect a printer to the wireless system....
Routers
I have two laps with same config, brand and VISTA home...
Routers
after u save thr running configuration at...
Routers
i tried portforwarding using portforward.com guide. but...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
