Question about Evesham PVR160 Freeview 10-Hours Video Recorder
Digihome PVR160 will not turn on.
There are no lights on the front of the box and the mains feed to the power supply is fine. Would anyone have a manual for this or any ideas,
  • 212 Answers
The power supplies to these units are prone to letting go. Unplug the unit, leave for awhile, then open it up. Have a look at the power board (the one with the power cable leading to it) and take a close look at the capacitors. If any of them are bulging or leaking, replace them.
Posted on Jan 12, 2010
On my digihome 32278hddled TV switching on with the remote control only brings up the sound but no picture what is the cure
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 10, 2017 | Televison & Video
Hi anyone know what number fuse is for cig lighter on a grand jeep cherokee 2003 please
which one, ???
cig or power outlets. there are 3. of them 2 front 1 rear.
the number is
fuse 26 runs cig relay. main feed
fuse 29 runs cig relay coil.
both are in the JB, junction box.
power outlet rear is fuse 27 PDC
power outlet front is fuse 9 JB.
May 12, 2016 | Jeep Cars & Trucks
My evesham pvr160 suddenly wont power on - fuse is ok.
Check its power cord first. If found OK, check and replace damaged component/s at its main power regulator section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Aug 02, 2014 | Evesham PVR160 Freeview 10-Hours Video...
Sony WEGA 36" will not
Sony sometimes use a balance power supply, similar design to the Philips design from1978 but updated. A realy efficient and nice design but when it dies it takes out quite a lot.
There is a mains fuse that feeds the bridge rectifier which in turn feeds the power supply. If that is the fuse you are refering to, seek professional help. The circuit is finely ballanced and must be correct otherwise it will go bang again. If this is not the fuse then look for a short circuit on/off switch or filter capacitor network on the A/C side, before it gets to the main power supply.
Hope this helps.
Dec 31, 2010 | Sony FD Trinitron WEGA KV-36FV310 36" TV
My VP504fhdtv10a vizio plasma TV when connect power cord the Vizio in front light up yellow/amber but will not turn on. I have replace Logic Control D Board still have same problem. I do research online...
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Nov 07, 2010 | Vizio VP504F 50 in. Plasma HDTV
No tail, parking, or dash lights. Also no turn signals.
you need to check the under hood fuse block on the right hand side you may find that one of the red feed wires has no power from the box either a maxi fuse or the box it self you could also check for power with a test light moving back from the components to the main feeds under the hood
Mar 10, 2010 | 2001 Chevrolet Impala
My sharp lc46sb54u 46 in.hdtv power light keeps blinking
Any indicator light on at all, if you see the light, then only the 5v standby power supply is working but not the main section of the power supply, it can also be the main control board hat is not sending signal to turn on the main power supply section.
Sep 01, 2009 | Sharp LC46SB54U 46 in. LCD TV
Digihome digital terrestial receiver Model DVB 915 I sitched the TV set off at night and then turned off the electric switch at the wall socket for both the TV and Digi Box. Next day the digibog...
hello make sure power is off take the top off the digibox see if you've got a glass fuse inside if the fuse is black its blown .where the fuse is holders is it should say what the fuse is rated at ie 1.25 amp put a fuse in with the same amps if it blows again then you have a dead short in the circuit good luck
Jul 21, 2009 | Televison & Video
Service Manuals for PVR160 by Evesham
I'm not sure if this will help, but here is a possible contact to try and get a manual. I know that went out of business. but I found this information on
A group of former staff from Evesham headed by former Evesham employee Robin Daunter started Tewktech, a company selling computers and offering repairs for a variety of brands including Evesham Technology.
good luck.
Apr 28, 2008 | Evesham PVR160 Freeview 10-Hours Video...
Evesham PVR160 Freeview 10-Hours Video Recorder Logo
801 people viewed this question
Top Evesham Televison & Video Experts
Are you an Evesham Televison and Video Expert? Answer questions, earn points and help others
