Question about Canon Office Equipment & Supplies
The colors on the file turn out totally different when printed on my Canon iPF 8000. I have a Epson and will print the same file and it will look the way it should be.
  • jim4279 Feb 07, 2009
    Cleaning the heads several times worked. I had not had any trouble with the Canon in the past, I guess I will pay closer attention to it in the future. THANKS
    President:
  • 1,990 Answers
Welcome to Fixya! You will need to Remove the Ink Cartridges and Clean the Contacts with Alcohol and a Q-Tip, Clean the Contacts inside the Printer also. If this does not work, You may need new Cartridges. Please Rate My Response! Thanks!
Posted on Feb 07, 2009
  • 679 Answers
There is a setting on the software, to get low color.
    Master:
  • 848 Answers
Make sure you are using the correct printer driver and make sure the paper size is correctly selected in the driver. If the printer is printing black only, the Ink option in the printer driver may be set to Black instead of Color or a setting in the software may be set to print black only. Also, the print head nozzles may be clogged. From the Utility section found in the printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Performing up to 6 cleaning cycles is not uncommon if the print heads are severly clogged
    Brigadier General:
  • Canon Master
  • 3,614 Answers
Do a print head cleaning. you can find it on the printer maintenance software installed on your PC.
  • micromaster
    micromaster Feb 07, 2009
    1. Do a print head cleaning
    2. Print the nozzle check pattern
    3. - repeat steps 1-2 up to two times -
    4. Do a print head Deep Cleaning (Note: the Print Head Deep Cleaning Procedure uses a lot of ink)
    5. Print the nozzle check pattern (This will print a test page using all nozzles in the print head)
    6. - repeat steps 3-4 up to two times -
    The printhead can also become clogged or blocked with paper debris or
    solidified ink. If your print quality is poor or your printer will not
    print at all, it may be time to change your printhead.
HOW CAN I RESET PRINT HEAD IPF 8000
https://groups.yahoo.com/neo/groups/Wide_Inkjet_Printers/conversations/topics/2373
Mar 10, 2015 | Canon imagePROGRAF iPF8000 Printer
Hello, i'd like to ask for advice. I have this one problem with canon ipf 8000, we've been using Schoeller H 64160 photopaper for poster printing with no problem. But recently we got different type of...
iI would check your paper type setting. you are working with a liquid type of ink and water will effect it. check the drying time of this ink. set your paper type to the set the type most suitable for this paper. try heavy gloss. you will find it under paper settings in the main menu. If no luck refer back to the ink and its compatibiliy with your ipf 8000. now if these are a recharged cartridges. you should change to the oem. meaning" original engineering manufacture".
Apr 09, 2017 | Canon imagePROGRAF iPF8000 Printer
My print head on my canon ipf 605 wont clean??
Hello!
I have printer Canon ipf 605 , on display is displayed print head error, I have put new print head, and the problem is the same, I tryed several print heads , most of them new , and it dont want to start....again and again printhead error is displayed...
Dec 11, 2010 | Canon imagePROGRAF IPF605 Printer
Ipf 8000 error E161-403f
I think you need to manually move the carriage unit and replace the print head but go into the service mode first and see whether its asking to have the print head replaced before you spend any money.
Sep 30, 2010 | Canon imagePROGRAF iPF8000 Printer
Ipf 8000 error code 003800500-2f-2f
there is no enough ink in the head managment sensor.
Go to menu, test print, nozzle check, check the grids 12 pair of grids.
Check if there are any brocken grids.
After that you have to perform head cleaning B twice or more.
If the problem still remains then replace print head.
also perform firmware update to the latest version though the official canon site
Mar 31, 2010 | Canon imagePROGRAF iPF8000 Printer
Uneven color lines
That is because it is printing the document as text. Not have=ing used a canon I presume it is the same as epson & HP. Instead of clicking the print icon click file print. A box should open allowing you to change the properties, seleect photo
Sep 18, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon iPF 8000: Hardware Error 03800500-2F2F and 03800500-2F30
it's a multiple problem....there is no enough ink for the head managment sensor to understand the good function of the print head.
Print a nozzle check to see what is going on
Then come back for more information
Feb 10, 2009 | Canon Office Equipment & Supplies
Canon ipf 8000 print head problems
You need to boot the printer into service mode.
Hold down the roll/source button and the info button while you are powering on the machine.
This should get you booted into the service menu where you can then access the replace printhead function
When you have successfully replaced the printhead, reboot the printer to get out of service mode,
You may also want to check the firmware version of your printer and update it.
Updates can be found on the Canon website
Dec 22, 2008 | Canon imagePROGRAF iPF8000 Printer
IPF will not print from PosterJet
in order to find out what is going on you have to print direct from the windows printer driver (print a test page) and come back.
Aug 13, 2008 | Canon imagePROGRAF iPF8000 Printer
16 people viewed this question
old marine
old marine
