Question about Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Whirlpool Duet Steam - bleach dispenser won't drain
I have a new front-loade and the bleach & fabric dispenser will not drain. The detergent drains fine.
SOURCE: Whirlpool Duet dispenser problem
I had the same problem my fabric softener would not dispense.Close shut-off valves and take off the water hoses off the back of the washer and look for blockage on the screen.Mine was plugged up and after cleaning it off it works like new.
Posted on Apr 03, 2009
  • 99 Answers
this is joyce
You need to call who ever you bought it from and tell them the problem that you are having, I have the same set and I am not having that problem at all. I love my set, just be sure to use the he detergent, or you will have problems that the manufactr will not help with.
thanks,
Dont overload machine the clothes wont smell clean.
joyce
Posted on Feb 07, 2009
scottludwig3
  • 4 Answers
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
Posted on Nov 17, 2009
  • 57 Answers
SOURCE: The fabric softner isn't draining during cycle but
When cleaning the softener chamber, make sure you remove and clean the syphon tube thoroughly. This is the only chamber designed to handle liquid. Otherwise, check that you have sufficient water pressure and that the cold valve opens fully. If you dont hear a decent gush of water during the rinse cycle, it's either pressure or the valve.
Posted on Dec 11, 2009
SOURCE: Detergent dispenser tray not draining water after cycles
I have the same problem and sometimes water stays in the detergent tray as well. I don't have a solution other than to remove the whole tray and drain in the sink after each cycle.
Posted on Dec 17, 2009
I have a jacket that was washed & the fabric stained from the detergent
Probably oxyclean? It has bleach in it and the jacket may not have been "colorfast". Or you may have had left over bleach getting into the wash. Or a bleach dispenser leaking?
Mar 21, 2015 | Whirlpool WFW9351Y Duet 3.5 cu. ft. HE...
Water won't drain out from the spots where fabric softener goes
It typically has some residual water after a load. All you need to do is to remove the detergent dispenser and dump the water out. To remove the detergent dispenser, pull it out as far it will go, then look into the detergent slot. There should be a horizontal plastic tab in the back of the detergent slot. Press the left side of the plastic tab and pull the dispenser out of the machine. Then you can dump the water from the bleach and fabric softener slots. Just slide it back into the machine and your good to go. Hope this helps.
Jul 12, 2010 | Frigidaire Washing Machines
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener is not dispensing
drain tube stopped up with softener needs cleaning
Feb 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Detergent reservoir won't drain after cycle finished. Water stays in it.
hopefully your using the HE type detergent an fabric softner, an not using but a teaspoon full each. the machine will detect if there is any product left in depenser. an too there will be some water left to keep lines an seals mosit. to keep from drying out so thats normal.
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
this is joyce
thanks,
joyce
Feb 06, 2009 | Whirlpool Washing Machines
Whirlpool Duet frontloader washer's dispenser stays filled
I had a similar problem, but mine was with the detergent side. I removed the top of the washer and had to clean the dial that advances to let the cyle of dispensing continue. It worked, but now the machine shakes and I am told is 'unbalanced'
Jan 16, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Whirlpool duet empties soap, bleach and fabbice softener as soon
soaps goes right in normal, bleach and fabric softer you can't go past max line line it will dispense."less soap plz"
Nov 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Detergent and fabric softener dispense at the same time
Whirlpool has designed this drawer as a siphon feed and soap and softener go as 1, 2 punch followed by bleach mid cycle.
Sep 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Sofner won't dispense
hi there remove the soap drawer then remove the cover over the softener compartment you will more than likely find a blockage in the cover siphon or the down tube on the drawer
Feb 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet 4.0 Cu. Ft. Steam Washer Logo
452 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
