Question about Intel DG31PR Motherboard
Restart pc ...when work is going on suddenly appear blue screen
Error occurs in my pc is restart
IRQL_NOT_LESS_OR_EQUAL
physical dump of physical memory
what i do to solve this problem
  • 217 Answers
This happens due to either a incompatible hardware or an incompatible device driver on your computer. Undo any changes you may have done before the error showed up and update the outdated drivers.in order to do that download the driver scanner tool which will scan the system for outdated drivers and give you and option to install the latest ones
click here to download
http://rapidshare.com/files/194341808/Unibluedriverscanner.7z
Posted on Feb 07, 2009
  • 70 Answers
This happens sometimes, but it's not very common.
Did you update any drivers recently?
Have you added any components to the computer just before this started?
You may have a faulty memory "stick". This is a link to Microsoft's Windows Memory Diagnostic. Follow the instructions to create a bootable CD, boot the CD and let it run and see if there are any errors.
Driver Irql not less or equal
You have lost a driver for the program mfewpak.sys or the system driver that is part of this program try this link.
https://www.google.ca/url?sa=t&source=web&rct=j&url=http://www.solvusoft.com/en/files/bsod-blue-screen-error/sys/windows/mcafee-inc/mcafee-total-protection-2011/mfewfpk-sys/&ved=0ahUKEwiBgqPzi8DLAhWMuoMKHbcsC2sQFggdMAE&usg=AFQjCNFDrzTvr_H6PXB1ScO_YdgbbdJVqA&sig2=r1WFj1-LX6CmVymdP3Pbyg
Mar 13, 2016 | HP Pavilion Computers & Internet
Driver irql not less or equal while server is working in win 2003 std server os this error will come on blue screen and after that we have restart the server. i have updated the bios and installed all the...
Use a utility like Nirsoft BlueScreenView to find the stop code from the crash dump. This may also allow you to identify the driver causing the issue.
If your USB ports are malfunctioning, this may indicate a hardware issue with either the ports, motherboard, or PSU. Check for obstructions, broken connectors or other such problems.
Please reply with more information such as the server model information, stop code, driver name, etc. for more help.
Oct 24, 2013 | IBM Computers & Internet
My dell inspiron 3521 laptop blue screens and says driver irql not less equal
Try removing all the appendages (USB drives, external hardware, etc. ) and restart the computer. Select the last best configuration.
Oct 06, 2013 | Dell Computers & Internet
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
I have a compaq nc6400 gives me blue screen of pfn lis corrupt and irql not less or equal i look up irql not less or equal and it's telling me that it's overheating and that maybe the ram is bad. help me,...
usually blue screen errors are related with the ram memory issues or ...corrupt (bad status) Hdd, but in your case probably one of the coolers doesnt work and it is overheating and forced to shut down suddenly ..,solution is to verify the ram memory ...and check the bios for any temperature limitations...and best is to restore the optimal defaults settings ...( factory defaults ) ...and also try to reinstall the operating system cause it might just have so issues ....also ...try to remove and replace the ram unit in its slot ..to be sure that its all ok ...
there is whatever the possibility that overheating damaged the ram memory already ,.and in this case it should be replaced... but this case its rare ...and ram memory if its not touched by hand ...usually has a life time exploitation period...
so ....either unlimited the maximum cpu temp allowed ..from bios...or find a way to install extra cooler fan...and reinstall for to be sure its all Ok...
Sep 04, 2009 | HP Compaq nc6400 (GJ982US) PC Notebook
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Blue screen of death
if your computer is getting this blue screen of death,then try getting in safe mode with networking of the computer& if you are able to go there you can uninstall & reinstall the video driver from that safe mode page because you will be able to work on that page...
Apr 25, 2009 | Acer Aspire One N270 Notebook
Lenvo blue screen error message when computer starts up
Please try to unplug the laptop from power and remove the battery for over 10 seconds. Then start it up again. There are other things we can try if this does not work.
Mar 19, 2009 | Lenovo 3000 N200 Notebook
IRQ nOT LESS OR EQUAL HEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEELP
irql not less or equal sounds like a graphics driver problem. All you needed to do was boot up in safe mode and remove the gfx driver and the OS would have rebooted with the default driver and then you could have reinstalled it
Oct 25, 2008 | Microsoft Xbox 360 Console
Intel DG31PR Motherboard Logo
122 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
