Question about GE Adora GHDA654LBG Dishwasher
No water going to the dishwasher
Motor runs stays dry no kinks in the line pulled line off d/w--dry, no clog nothing coming from under sink-definitely turned on Is there some sort of pump that pulls water from under the sink up into the d/w?
  • jonepstein Feb 07, 2009
    yeah. I thought that might be the case. Appreciate it.
  • 6,784 Answers
Actually there is a pump that moves the water threw channels. this pump may be experiencing motor issues. i would find a repair man or, if you good a disassembling the dishwasher, you can extract this part and replace it at you local appliance shop.also, this pump assembly could be jammed as well due to an object.
Posted on Feb 07, 2009
  • Michael Masters
    Michael Masters Feb 07, 2009
    no problem. thanks for using fix ya:)
My GE Triton dishwasher won't drain. How do I de-clog it?
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Apr 24, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
Frigidaire Dishwasher Professional Series runs loud now and the dishes aren't clean when it finishes its cycle.
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
Feb 26, 2011 | Frigidaire Professional Series 24 in....
Machine runs but doesn't allow water to come into machine
Don't know the history of your machine, sounds like possibly the hot water supply valve under your sink is turned off. To check this go under your kitchen sink and inspect water supply valves, (right side cold water) left side hot water valve feeds the machine. Vertical water line is for sink above, there should be a second water line coming off this valve that has its own on/off knob. Make sure this knob is turned on, (counterclockwise)if not sure turn it to the right (clockwise)till stops, then to the left till it stops. This allows hot water to enter dish machine. If valve is on and line is ok, there might be a kink in the line behind the dish machine or a restriction (clog) in the water line. May need to unplug machine and unsecure it to pull it out for inspection. Good luck,best regards.
Feb 10, 2011 | Maytag Dishwasher
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Wash cycle doesn't seem to work. bottom has water
Your gonna have to pull the dishwasher out and shut off the water line. Then disconnect the water hose and get you a bucket. Then turn on the water line to see if water comes out. If water comes out strong then your water supply line is good, which means your inlet port on the dishwasher is clogged or hard water has clogged the little holes in the dishwasher arms. Dishwashers are meant to leave a little water remaining at the bottom to keep the sensor from burning up.
Feb 16, 2010 | Dishwashers
Soap stays in disperser. Water is 142 degrees, dispenser opens.Not overloaded and filter under bottom wand is clean. Model is 16342
Either:
  1. check if the bottom rack is inserted correctly. Try turning it 180 degrees and run the cycle. Make sure nothing obstructs the dispenser.
  2. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, if you don't see any water at least once - check water valve, water level float and water pressure.
  3. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  4. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Feb 16, 2010 | Kenmore 24 in. 16352 / 16354 / 16359...
Motor runs when door is open- water does not come in- seems stuck
depending on the brand and mdl the unit may be equipped with an overflow safety. If ther is water under the dishwasher in the floor pan then the sensors will trick the dishwasher into thinking it is leaking. Check under the kick plate . if it is moist then take a hair dryer and dry it up up until there is no moisture at all. This should cancel out the pump command and you can start over .
Jun 13, 2009 | Bosch Integra® 500 SHX46A0 Dishwasher
Dishwasher was moved due to flooring & water now will not come in
1st check to see if the water supply is on , check for kinked supply line to dishwasher ,check to see if electrical connections are on valve and 1 more thing is to check if float is jammed (float is a mushroom shaped part located inside front of tub on bottom) just pull up slightly
Dec 21, 2008 | Dishwashers
How to install built-in dishwasher w/out kinking water lines?
I eventually unhooked the hotwater line where it comes in below the sink in order to give the slack I needed to hook it up to the elbow on the front of the dishwasher...then slid it into the 24in. space, but found that my hotwater line was 4 inches short! A trip to home Home Dept to buy more line and connectors solved the trick and now it is all hooked up and works with no leaks.
Nov 30, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 17245 won't drain.
Try blowing into the drain line with a wet/dry vac. This sometimes removes clogs. Otherwise, hold the hose above the unit and fill it with water. If there is no clog the water should appear at the bottom of the dishwasher after a few quarts.
Nov 29, 2007 | Kenmore 17245 Dishwasher
GE Adora GHDA654LBG Dishwasher Logo
135 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
