MY RCA MODEL NUMBER D52W19 WONT TURN ON!
Hello ,
I believe this may be a HV/LV power supply problem since this is a common issue in this RCA ITC222 chassis, I posted this earlier and I beleive that it can help you,
Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I would also like to say that if possible you should get a qualified TV Technician to repair this set for you, due to the nature of this problem and the dangerous voltages present.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
