Back to:
Tags:
Aprilaire 600 Humidifier
Installing natural gas furnace (Carrier Infinity...
By Bray - usenet poster
I am replacing natural gas furnace and humidifier for my house. I got
estimate for this from local company. What I am wandering about is that this
furnace has variable speed motor that runs all the time. Because humidifier
usually works the same time as motor is running, it means that my humidifier
will run all the time.
Q: Are there on the market special humidifiers that are specifically
designed to work with such furnaces?
P.S. I contacted aprilaire and they told me that their humidifier will work
in such setup, just I have to use hot water for humidifier. But I am not
sure at this point if this would be efficient setup.
Thanks
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Aug 01, 2007
FixYa! (100)
Rogers
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Carrier Infinity 96... Carrier's MVP furnace.
variable speed blower - quiet and reliable.
circuit board controls humidifier power (24VAC),
whether it be a "Carrier" or "AprilAire" brand
Carrier furnaces have a humidifier "tab" on their boards,
eliminating the need for a secondary power source.
The humidifier low voltage power is controlled
by the circuit board on the furnace. It will not
"run all the time."
This depends on what humidifier you are getting.
The "basic" comes with a cheap humidistat which can
can be used to control the humidity.
OR
You can have a Carrier Thermidistat installed,
which comes with an outdoor sensor to control the humidifier
without the need for a seperate humidistat. The same holds
true if a Carrier Infinity Control is installed.
OR
You can have either a Carrier or an AprilAire humidifier that
has an outdoor sensor included with a special humidistat that
controls the humidity more "smartly" in your home.
Hot water works best for evaporative-type humidifiers,
no matter what "brand name" they are.
Since this allows for better and quicker humidification,
it reduces the amount of water required to add humidity
in your home (less drains out since more is added to the air).
This reduces your water bill.
you're welcome.
peace,
-Gate
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Installing natural gas furnace (Carrier Infinity 96) and humidifier (Aprilaire 600) - with motor running all the time:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Beresford
Rating: 0%, 0 votes
'just I have to use hot water for humidifier. But I am not sure at this
point if this would be efficient setup.'
ME: Using hot water for the humidifier instead of cold ,increases the
evaporation capacity of the APrilaire . It will obviously cost you a bit
more in energy because your water heater will be running a bit more
often. What i would do, is , plumb cold water to the humidifier and
see how it works---if you find your house lacks humidity, then switch it
over to using hot water. All it takes is another saddle valve...IF local
codes allow. SOme towns by me, dont allow humidifer saddle valves.
dave
Have you hugged your A/C Tech today ?
Thank You!
Solution #3
Not Rated (0)
herself
Rating: 0%, 0 votes
The humidifier is turned on and off via the humidifiers humidistat ;
the blower running only 'enables' the humidifier to run IF humidity is
being called for.
Therefore, your APrilaire is compatible with a variable speed furnace.
Dave
Thank You!
Solution #4
Not Rated (0)
Beresford
Rating: 0%, 0 votes
alt.home.repair for home owner questions, please.
Paul ( pjm @ pobox . com ) - remove spaces to email me
'Some days, it's just not worth chewing through the restraints.'
HVAC/R program for Palm PDA's
Free demo now available online #
Free Temperature / Pressure charts for 38 Ref's #
Thank You!
Can you Help with these Humidifiers problems?
Humidifiers
I am servicing a Carrier humidifier M/N: HUMCCSBP2017A. ...
I have 2 issues. 1. My humidifier will only dispense water...
Last year my 600 humidifer worked just fine. This year it...
I just changed my filter on my 600 and ran the test and it...
how i can chagne the filter
Loading problems.
Repair Service
Find Humidifier Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
