Question about Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter
What is the pairing code
I lost the box, wht is the code my phone needs to connect?
  • 30 Answers
The default is usually 0000 (that's 4 zeros)
Posted on Feb 07, 2009
I have lost my Bluetooth manual and have switched phones. How do I reprogram it to the new phone?
Hi,very easy.It's just the same way you paired the blue tooth with the phone.Dothe same with the new phone are you are done.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Have a nice day.
Sep 01, 2010 | Cell Phones
I didnt Connect my Blue tooth Headset to Samsung E1410...so wht is the procedure,
hold the power button till it flashes blue an red with a fast pattern the pick search on your cell when it finds it click pair then type in (0000) as the pairing code if that one doesnt work try (1234)
Aug 04, 2010 | Radio Communications
I need the factory pin code I have lost it
Hi,i think you have problem with the code used in pairing your bluetooth device,the default code to connect to your bluetooth device is "0000".
Good luck
Jun 11, 2010 | Samsung SGH-U600 Cellular Phone
I lost the instructions that contain the unlock code to enable bluetooth access... I got one of those bluetooth adapters for my computer and i'm trying to pair my computer with my mobile phone. My phone is...
If you want to pair the phone with the PC through BT then all you have to do is to give and number like 00 or 0000 as the code. on the phone and press enter. Then the PC will ask for the code. You should give the same number there too, ie, 00 or 0000, whatever you gave earlier. Then the phone will connect to the PC through BT.No instruction manual is required for this. Once your phone and PC are paired you can set then to connect with out this code being given every time.
Dec 04, 2009 | Computers & Internet
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 | Cell Phones
I've lost my pairing code how can I get another on, or is there a
From the Motorola Website:
The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
This should work for you, but if it doesn't you'll to contact Motorola
Dec 05, 2008 | Motorola Mobility HS850 Consumer Headset
Jabra 250 Codes
To make this complete: You need to turn off the headset (hold call button several seconds until it makes descending tone). Then hold button to turn on and keep holding 8 seconds more until blue light is on solid. Then initiate pairing at phone, and enter 0000 as the code.
Mar 24, 2008 | Jabra BT250 Consumer Headset
Pin code for a HBH-608
Lost the manual and now I can't re-connect with it,,phone sees it but can't be paired cause no pin cod
Dec 30, 2007 | Cell Phones
Insignia Bluetooth Wireless Headphones with USB Bluetooth Adapter Logo
183 people viewed this question
Top Insignia Radio Communications Experts
Skyken
Level 1 Expert
woodzowl307
Are you an Insignia Radio Communication Expert? Answer questions, earn points and help others
