Question about LG LU20 Tablet PC
Dismantling the LG LT20 back cover
I need to reach the power-supply socket internal connections to re-solder them.
Also, I need to tighten the screen-to body swivel joint.
Where can I get Dismantling instructions?
  • ofersol Feb 23, 2009
    I opend all the screws on the back cover, then released the plastic hatchets, but still the back cover cant be removed.
    It seems like there are screws somwhere under the keyboard that are holding it from the other side.
    Are you familiar with that?
    The model is: 2703H-LT20.
    Please read carefully my problems: reaching the power socket legs, and tightening the screen swivel joint.
    Please read carefully what is my problem: still cant remove the back cover, to reach the power socket.
    President:
  • 2,653 Answers
I don't think anyone will be able to provide you with a service manual here, but that's OK since common sense is the best tool when it comes to opening up a laptop.
First thing you'll want to do is find a nice clean surface to work on. Just start unscrewing every screw you see. Don't be afraid. They're only screws.
Take your time and just work your way into the laptop. If you just do that you should be able to open about 90% of all laptops out there.
If you get stuck let me know and I'll guide you with specific instructions.
I've got faith in you.
As far as the tightening issue goes, you might not be able to tighten it up depending on how it's manufactuered. Again just use common sense and you'll be fine. If there is not way to tighten the swivel because of how it's made, then just swap the part with one from ebay.
Best of Luck!
Posted on Feb 23, 2009
  • 544 Answers
Thank you for choosing fixya.com
click to this link and you will be directly connected to manual of your laptop just follow the instruction carefully.http://safemanuals.com/user-guide-instructions-owner-manual/LG/LT20-123A-_E http://www.irisvista.com/tech/laptops/ToshibaM205/Portege_M205_disassemble_1.htm
  • 547 Answers
Http://www.aplusperfect.com/articles/lg_xnote_p2_disassembly here is a site i think will help you thank you for useing fixya please rate me
  • 1 more comment
  • albert getty
    albert getty Feb 23, 2009
    please take each step carefuley and keep screws sep/ as some are differnt size
  • albert getty
    go to this link for step by step instructions thank you
  • albert getty
    Step 1: Remove all screws from the bottom of the laptop. Afterwards remove the hard drive, memory, and wireless card. Make sure to remove the two small screws under the hard drive and battery.
    Step 2: Use a small flat head screw driver to push the four keyboard latches back then lift up the keyboard and disconnect the keyboard flex cable.
    Step 3: Remove the top five screws, leave the heat sink and cdrom screws in place.
    Step 4: Use a spudger or flat head screw driver to open the plastic snaps along the perimeter of the case then remove the case.
    Step 5: Remove Plastic LCD hinge covers by unscrewing the black screws on either side.
    Step 6: Unscrew the frame assembly, disconnect the CMOS battery, disconnect the flex & LCD cables.
    Step 7: Remove frame assembly. Lift up and out.
    Step 8: Unscrew/Remove the Chipset/Video heat sink
    Step 9: Unscrew/Remove Heat Sink
    Step 10: Unscrew/Remove CDROM
    Step 11: Disconnect speaker wires and remove speaker assembly
    Step 12: Unscrew motherboard, then wiggle the motherboard out. (make sure you remove the PCMCIA, SD, and Modem plastic inserts)
    Sergeant:
  • 250 Answers
The pictures were taken using a SE w810i, so the quality is not the best.
1)
The first step is to unscrew two screws located on the back of the notebook.
Pic; http://peecee.dk/?id=29138 http://peecee.dk/?id=29139http://peecee.dk/?id=29140
2)
Next, take a look at your notebooks keyboard. Four "clips" is situated at the top of the keyboard. To unhook the keyboard these clips should be pushed into their sockets.
Pic; http://peecee.dk/?id=29141
To do this ive just used a kitchen knife with a blunt end, as seen in the pictures below. I guess a small screwdriver would do the job just as good.
Pic; http://peecee.dk/?id=29142 http://peecee.dk/?id=29143http://peecee.dk/?id=29144
3)
When these clips are pushed in, the keyboard comes right off the notebook. And you have acces to one of the ram sockets as seen in the pictures below. To set the keyboard back on, just push it into the fittings and down on the notebook and the clips come right out again. Remeber to screw on the screws at the back of your notebook again.
Pic; http://peecee.dk/?id=29145 http://peecee.dk/?id=29146
this link will give you more details on this dismanteling issue http://forum.notebookreview.com/showthread.php?t=105392
    President:
  • 2,110 Answers
    Sergeant:
  • 326 Answers
You will have to download the manual for this to exactly get the instructions http://safemanuals.com/user-guide-instructions-owner-manual/LG/LT20-123A-_E click the link below to get this instructions. 1)Turn the unit upside down.Remove the battery.Remove one screw securing the hard drive cover and one screw securing the memory card cover. Remove all covers. 2)Remove the laptop hard drive disk.Remove the memory modules.3)Remove all marked screws on the bottom of the laptop.4)Turn the laptop right side up.Insert a thin object under the securing strip and lift it up.
Be careful, it may be very tight.5)Remove the keyboard securing strip.6)Remove two screws securing the keyboard.
Turn the keyboard over and place it on the palmrest upside down.7)Disconnect the flat keyboard cable on the system board and remove the keyboard.8)Disconnect the notebook touchpad cable on the system board.Disconnect the LED board cable on the system board.
for diagrams and more detailed help click this as the brand is different but the system is same  http://www.irisvista.com/tech/laptops/ToshibaM205/Portege_M205_disassemble_1.htm
    Brigadier General:
  • 8,619 Answers
Please follow this to dis-assemble it-
Remove the keyboard screws from underneath the laptop, then flip over and use a flathead screw driver to unhook the hidden keyboard tabs on the top of the keyboard.
Once you've removed the keyboard you then remove the cable wire which connects it to the motherboard, this will also reveal the extra RAM slot which should already be occupied by the RAM that came with your notebook.
This also reveals the CPU, etc. You can remove motherboard mount screws, etc.
To remove the LCD casing;
Remove the rubber pieces from the mounts, then remove the screws from here. Once removed you should be able to snap out the LCD panel case starting from the bottom, but do this carefully as you could stuff up the panel.
Removing the keyboard on its own should give you good access to upgrade all the parts. The LG's have a great heat pipe cooling system!
Please tell the model no. so that i can help you.
    Scholar:
  • 165 Answers
You will have to get proper screw driver to make it open as it is just attached on screws and some locks of plastic.
    Brigadier General:
  • 3,614 Answers
may i know exactly the model and # you have?
  • micromaster
    micromaster Feb 23, 2009
    go here and download the manual HERE
How to fix power socket on D70PRO
The only option is to buy a used one from a local seller or eBay.com or just purchase a new PCB that's the only option if you try to connect to the battery direct you stand a good chance of causing it to explode! Good luck!
Mar 03, 2015 | Tablets & eReaders
My tablet wont charge it was purchased nov 2013
the internal battery has reached it's lifespan.....use power bank if you don't want to replace the internal battery..the tab will get the power from the power bank...powerbank is a recharcheable battery with usb connection than can be connected to your tab to power it up....
Oct 15, 2014 | Tablets & eReaders
Kindle won't hold the plug to charge anymore. I have tried differenct chargers, they don't work.
Once the internal connector of the tablet is broken (which is what you are describing), there is no hope but to find someone willing to replace or repair the connection. The device was not designed to be repaired and nobody has been specificly trained to do that repair except the fellow in China who works on the production line doing that exact task on production "fallouts". There may be an "old school" electronics technician somewhere who could do the job but very tough to find one. It will be cheaper and easier to buy a new tablet.
Sep 19, 2014 | Amazon Kindle Fire HD
Nexus 7 problems
Pop the back cover off. It's real easy - you can use a credit card or even your fingernails. Carefully prise all around the edges. It'll come off quite easily. Looking from the rear with USB port at the bottom, you'll see the left side if the unit is occupied by a large rectangular battery. At the top right of the battery is a connector with six wires. Gently disconnect the connector from the main board. Leave disconnected for about 30-60 seconds and then plug it back in.
Put the back cover back on, and then plug in the charger.
You Nexus will charge fine.
Jul 16, 2014 | Google Nexus 7
Battery wont charge
Is it a different charger? If it isn't try plugging it into a car or at home on the computer or the wall. If that doesn't work maybe getting it checked out will help.
Jan 07, 2014 | Amazon Kindle Fire HD
Digit tab 1030 power button does not work
It's prob broken it's solder connection. Re-solder or you can power it up by coneecting it to a powered up computer via its usb socket. When it's booted you can disconnect.
Jun 03, 2013 | Tablets & eReaders
My New Amazon kindle 3g just froze and I don't know how to take off the back cover what do i do?
Do not remove the back cover, there are no user serviceable parts inside. Instead:
  • Make sure the Kindle's battery is charged. Connect to a PC using the supplied USB cable until the power LED changes colour from amber to green.
  • Slide and hold the power button until after the power LED blinks three times. If the screen now is blank, repeat the procedure
If the Kindle still does not come back to life, contact Kindle Support.
Dec 25, 2010 | Amazon Kindle 3G
How to disassamble LG LT20-486E1? How do I take my LG lt20 lapton apart to put a new ventilator in it?
sorry to say that an error 52 is usually related to the laser which will require a service call..not much you can do about that...
Thank You For using FIXYA!!
Dec 01, 2009 | LG LU20 Tablet PC
My laptop will not charge. If I hold the connection at the computer, and jiggle the transformer portion of the charger cord, it will charge briefly, but not continously. I have unplugged and replugged the...
When you plug in the adapter and wriggle the power plug and the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. You can DIY but if not confident to tackle it yourself then, I suggest you get a quote for the repair first.
Nov 26, 2009 | Toshiba Portege M400 PPM40U01000E Tablet...
Lost keyboard driver
all the drivers for this notebook can be found here :http://www.notebook-driver.com/lg/lg-notebook-lt20-driver/
Jan 25, 2009 | LG LU20 Tablet PC
LG LU20 Tablet PC Logo
473 people viewed this question
Top LG Tablets & eReaders Experts
Jax Planet
Jax Planet
Andrew Taylor
Andrew Taylor
micky dee
Are you a LG Tablet and eReader Expert? Answer questions, earn points and help others
