Question about Panasonic TH-50PX25U/P 50 in. HDTV Plasma Television
Th50px20 i have a sc 2 card in my th50px20 #tnpa2914a/b ez3004d can someone tell me if a card with the number tnpa2914a/c ez4520d will fit i can,t find a interchange number anywhere
  • ronsbaby Feb 07, 2009
    yes i have tryed everthing i could think off and came up with nothing the thing i cant unstand iss the ez3004d nimber
    still looking for a answer to the question on what the ez3004d number is for and if there is a interchange out there somewhere
  • 679 Answers
Please tell me whats this card about ?
Posted on Feb 07, 2009
  • rockfixya
    rockfixya Feb 07, 2009
    There is no that kind of card on net for your Plasma TV.
    Sergeant:
  • 326 Answers
It will not fit if its not for the exact model made.it will not get detected .it will show nothing.
My SC-D363 will not recognize the SD Memory Card.
The SC-D363 only can handle up to a 1 GB SD memory card, no larger, so if you are not using a 1 GB or smaller card, then that is your issue.
Jan 17, 2013 | Samsung SC-D363 Mini DV Digital Camcorder
Sc 990
SC990 [Cause]
Dirty contacts on Upper Right Cover Safety Switches. Toner gets inside the Upper Right Cover Safety Switches, which can lead to lower DC voltage being applied to the Laser Diode. Which leads to:
SC 990 eng_procon.c (when a normal Grayscale pattern was not detected 15 times consecutively during ID Sensor Grayscale pattern check) check with SP 7403 Service Code History look for Detail in history of SC 990.
LD Power not being strong enough to be read by Laser Synchronizing Detector causing a SC 322 or 326 depending upon timing.
5vdc not being fully applied to connector 403 pin 3 on the Laser Diode PCB causing an Open Cover Indication, or 24vdc not being applied fully to connector 107 pin 2 on the PSU PCB causing an Open Cover Indication.
Circuit Explanation: 5vdc (VCCD)is output from connector 403 pin1 of the Laser Diode PCB where it travels through 2 of the Upper Right Cover switches than through 2 of the Front Cover Safety switches before being applied to connector 403 pin 3 of the Laser Diode PCB where it is now used to power the Laser Diode. Lower voltage on pin 3 leads to lower laser diode output which causes the machine to raise LD Power (SP 2-103) when maximum values are reached, laser diode output can not be increased further which can lead to SC 322, SC 326 and/ or SC 990 eng_procon .c. If the voltage drops too low an open door indication is sent to the BICU PCB but a signal is not sent to the IOB PCB which tells the machine which door is open.
Note: An older Drum more than 150,000 copies can also lead to SC 990 by causing incorrect ID Sensor readings
[Resolution]
1. Clean the internal contacts or replace Right Door Safety Switches (2 of Part Number 1204 2521 and 1 of Part Number 1204 2529)
Clean and vacuum the PCU.
Clean the Toner Shield Glass, Charge Roller and ID Sensor.
Check Service history for Drum Life, if over 150,000 replace Drum (Part Number A230 9510)
Reset SP 2103 -1 thru 4 to defaults.(LD Power Adjustments)
Reset SP 2001-1 to its default. (Charge Roller Bias Adjustment)
Execute SP 3001- 2 (ID Sensor Initial Setting)
Sep 08, 2011 | Ricoh Aficio 450 Copier
What should I do to solve error sc 9900 appears when the machine is in operation
[Cause]
[Resolution]
Sep 02, 2011 | Ricoh Aficio 2035 Copier
I am trying to find a SD card that will work in my Samsung Digital-cam Model: SCD 103. A regular SD card will not fit in the slot on my camera. The manuel just calls for a SD card. I need more details.
The SC-D103 doesn't take SD cards. It takes Sony Memory Sticks and compatibles from third-party manufacturers such as Lexar and Sandisk. Be careful, it will not take Memory Stick PROs.
Oct 09, 2010 | Samsung SC-D103 Mini DV Digital Camcorder
GPS Meridian - unlock SC card
Call Magellan and tell them the web page you were dircted to has been removed tell them your license number and they will unlock a sd card when you give them the sd serial number I went through this two years ago.the link you need has been removed from there server
Jul 18, 2010 | Magellan Meridian Marine GPS GPS Receiver
Sylvania DV-2100 Deluxe DV Camcorder. It keeps
We had the same problem.I went online and found some info after Googling the model number. There is a tiny SD card that goes into the SD adapter(this black small rectangle fits into a larger rectangle) a. When you insert the smaller one into the larger one, make sure the camera is off. I even took out my batteries and then inserted the card. It should work after that. Good luck.
Dec 29, 2009 | Video Cameras
Technics ho2 no play error
u need a new motor in yr dvd player i had same problem so had new motor fitted cost 50 pound works now
Sep 20, 2007 | Technics SC-DV290 System
What is the voltage, current, and polarity of the power supply for the SC-D23?
You should use the original Samsung supply since it is a switching power supply capable of supplying the needed current to operate the onboard charging circuit. Many customers have tried to go with generic supplies and it opens the inline chemical fuse due to the unit drawing heavy current during battery charging. Hope this helps. Joe Weibel Custom Electronics Memphis, TN 38133 (customelectronics.org)
Feb 12, 2007 | Samsung SC-D23 Mini DV Digital Camcorder
Panasonic TH-50PX25U/P 50 in. HDTV Plasma Television Logo
41 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
