Question about HP Photosmart 8250 InkJet Printer
Need instructions on how the load and use the hp photosmart 8250
Just need instructions on how to use and load the cards and paper for photos scanning.
    President:
  • 2,110 Answers
New sd card, when putting it into my hp 8250 the printer says "card access error". I need the photos that are on the card!
Try downloading the photos off the SD card by inserting the SD card into anUSB card reader and connecting it to a computer's USB port.
This computer should detect the SD card as an external storage device, then you can copy the photo from the SD card to your computer's hard disk.
May 26, 2011 | HP Photosmart 8250 InkJet Printer
The paper won't feed properly. Regualr of photo. It constantly says there is no paper when the tray is full.
Try changing the type of paper that you have under your printing preferences into hp premium photo paper instead of automatic.
Feb 14, 2011 | HP - HP Photosmart 8250 printer
How do you remove paper tray on hp photosmart 8250 printer to clear paper jam
Hi we2halls,
You may want to try the procedure on this link to help you clear the "Paper Jam". It includes detailed instructions and some illustrations.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | HP Photosmart 8250 InkJet Printer
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
Oct 11, 2009 | HP Photosmart 8250 InkJet Printer
Out of paper message when there is paper
This video is for the C7280, but the instructions are supposed to be true for the 8250. Usually that message when you have paper means that the rollers in the printer are slick and not picking up paper. The video shows how to fix that.
Feb 10, 2009 | HP Photosmart 8250 InkJet Printer
Daughter left HP Photosmart 8250 idle for a year. Have just put in new ink, but paper will not load. How to service?
unplug the printer from the power and from the computer..
open the back door of the printer and check if both the rollers (inside the printer & on the door) are rolling (upwards)..if not then press & Hold the Power button for 60 seconds when unplugged from the power..
If the rollers still dont move..then u need to service the printer..
if rollers moves..then connect the power cable to the printer and directly to a wall jack (not to a power strip)..
power on the printer and load paper in the main tray..(ensure photo button is not lit up)..
photo button should be lit up in case u want to print photo and the paper is placed in the small phto tray which is exactly above the main tray...
place the paper to the xtreme right in the tray and slide the paper guide from left to right..
then try printing ..
Dec 24, 2008 | HP - HP Photosmart 8250 printer
My printer isn't grabbing the photo paper
have you tried with normal paper..does it still do the same
when you load the paper does the roller sit on the paper at all...watch the roller....
but if your machine reports that there is no paper even though the roller is sitting on the paper
turn off your printer//remove the ink cartridge.....get a can of contact cleaner..with the nozzel on..throughy spray the roller area this is where the papper sensor is...
if this still doesnt help you will need to open the printer and check the sensor
keep me posted
Cheers
Nov 17, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart C6100 All-in-one Series
I want to print a 4 x 6 inch photo on the 4 x 6 inch photo paper but not using my memory card. I no longer have what I want on the memory card but I have a copy of the photo I want to print in a computer file. How can I get it to be pinted on the 4 x 6 paper rather than printing on an 8 1/2 x 11 page and having to cut it out.
Jun 20, 2008 | HP Photosmart 8250 InkJet Printer
8250 hp printer
Adjust the paper settings in the print driver. The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program in which it was created.
  2. Click File .
  3. Click Print .
  4. Click Properties . The Printer Properties dialog box displays.
  5. Click the Paper/Quality tab.
  6. In the Size is drop-down menu, select the size of the paper loaded in the unit.
  7. In the Type is drop-down menu, select the type of paper loaded in the unit.
  8. Click OK .
hp website
Jan 29, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart 8250 InkJet Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
