Question about Initial HDTV-320 32 in. LCD TV
Can't get all digital channels
I have an Initial 32" Lcd flat panel tv The model number is : HDTV-320 I can recieve all channels in analog but not in digital I also have an amplified antenna that really brings in reception... Can anyone help me to find out why I can't get all digital signals?
  • Initial Master
  • 5,268 Answers
There are several possibilities assuming you have an outdoor antenna with the amplification. You are too far from the transmitter or the station is still on a low power digital transmitter until the analog broadcasts end. Additionally, there may be buildings, hills or trees in the way. The first one is called the digital cliff - you either have enough signal for your tuner or you don't. Some stations may need to add transmitters to cover the secondary areas that could still receive the analog signal. The second possibility will either resolve on Feb 18 or June 12 or anywhere in between. (It will depend on your station and the Digital TV transistion delay bill. Some stations are changing frequencies with the transistion and can't go to full power until another analog station moves its frequency.) The last one can't be resolved.
If you have an indoor antenna, you can try moving it around to get better results. My household has an amplified outdoor antenna with a rotator to get the antenna to line up with the signal. We have two analog stations that give problems when we look for their digital signals. We hope the issue will resolve with the changeover since we have seen the signals on both stations improve when they wanted to broadcast football games.
Posted on Feb 07, 2009
What can make the screen go black on a Initial HDTV-320, there is no prolbem with the sound?
It is usually the sustain driver board that powers video. I'm looking for one now for my Samsung. Best thing to do is replace it if you can find one on eBay. They are easy to replace. You will need your old board part number and model of TV, use only the exact matching board part# or you may create a fire or electrical hazard. Always wear gloves, capacitors hold voltage for a couple of days. If bare skin touches one that still has a charge you will know it.
May 24, 2014 | Initial HDTV-320 32 in. LCD TV
No signal for HDMI or DVI
Hi, what device or devices have you tried to connect through those ports? Were they working prior to this problem?
Mar 19, 2014 | Initial HDTV-320 32 in. LCD TV
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Jan 16, 2010 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Will not find digital channels
bad digital module on the main pcb
Aug 09, 2009 | Emerson LC320EM8 32 in. LCD TV
Blue sreen with message sayin this is an encrypted channel
call Comcast and do nothing more. if they messed it up make sure they fix it or you could be out a tv and a cable box. if they wont then call the manufacturer of the tv.
Jun 01, 2009 | Initial HDTV-320 32 in. LCD TV
Stuck on a video mode
Some TV's disable inputs if there is no signal. I suggest confirming cables are connected properly, and accessing the system menu, and perform an autoscan for channels
Apr 27, 2009 | Initial HDTV-320 32 in. LCD TV
Vizio tv chanel search is not finding digital chanels.
On your remote, select input as TV, then verfiy that you have set to Antenna, Then scan for channels.
Mar 16, 2009 | Vizio L32 32 in. LCD HDTV
Initial HDTV-320 32 in. LCD TV Logo
1,312 people viewed this question
Top Initial Televison & Video Experts
mega_mind
Are you an Initial Televison and Video Expert? Answer questions, earn points and help others
