Question about RCA R52WM24 52" HDTV Projection Television
Fuse keeps blowing R52 WM24 tv
The fuse that controls the convergence keeps blowing...any suggestions
Picture does not come on, on button lights up and goes out 3 times and stays shuts down. ABC
Posted on Jul 19, 2010
  • RCA Master
  • 8,617 Answers
You need to replace DL231, FL231 and CL230 all at the same time then resolder the flyback and vertical IC, You can get the parts under the RCA category at the following link, and they provide instructions on how to do the repair.
Posted on Feb 08, 2009
RCA R52WM24 52 in TV
the RCA service bulletin says to replace FL231, DL231 and CL230 all at the same time then reflow the solder on the flyback and the vertical output IC
Feb 07, 2009 | RCA R52WM24 52" HDTV Projection Television
High pitched noise related to the color shifts. RCA 52"
Coil LL037 resolder then glue top with stick glue or replace coil.
Jan 19, 2009 | RCA R52WH73 Projection Television
Power problem on Pioneer Pro-700HD
The failure is not on the power supply but the convergence amplifiers STK ICs have the 24 volts shorted.
If that fuse is blowing, de-solder the convergence ICs and put a new fuse to power up the TV; you should see distorted video when the TV powers up and the fuse should not blow.
The service manual migth not help much in this case since the failure is easy to pin point.
Good Luck.
Oct 03, 2008 | Pioneer PRO-700HD 64" Rear Projection...
Tv model r52wm24
You most likely need a new convergence power supply board if fl231 keeps blowing thats the most likely cause, also check for shorthed capacitor cp231. If you need a link to get a replacement convergence power supply board, let me know I know where you can get them.
Jul 19, 2008 | RCA R52WM24 52" HDTV Projection Television
RCA HD52W59 Convergence issues after some repairs.
Hello rmolen,
This is an indication that the convergence amps are drawing too much current which has an effect on the power supply and thus killing your sound by removing or lowering the voltage supplied to that stage, finally this results in the blowing of the fuse. I would suggest that you change the convergence amplifiers and the biasing resistors (All of them) and then see if this corrects your problem (I believe it will). Also get a schematic of the TV and try to find out how the power supply relates the sound module and the convergence module, they might share a common power bus, or the voltage regulator for the sound also feeds the convergence board.
I hope this helps,
Thank you,
Jul 08, 2008 | RCA HD52W59 HDTV Projection Television
Convergence fuse Toshiba rear projection tv
Wire jumpers need re-soldering....Locations 008,010,017 etc
on inside edge of signal board near convergence IC's.....research
my Toshiba " H " Model rear projection " blows fuses" solutions.
Jan 27, 2008 | Toshiba 55H70 55" Rear Projection...
KP46V15 Convergence problem
You must have checked fusible resistor?
check convergance control panel and check voltage supply to this board.If voltage are o.k than you have to change convergance control ic which is smd ic and its on the control board.
Dec 10, 2007 | Sony KP-46V35 TV
Pioneer sd-643hd5
Sony Convergence
Nov 03, 2007 | Pioneer SD-643HD5 64" Rear Projection...
RCA R52WM24 52" HDTV Projection Television Logo
171 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
