Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
Electrolux Built-in with no water going throught built in filter.
I have bad tasting water at the door filler valve but water is not going through the built in filter. When I pull the filter it is bone dry. Any ideas?
I have a MagTag Plus side by side. It is leaking water onto the floor and inside the freezer. Any solutions?
Posted on Feb 07, 2009
Water Filter
The minerals could be built up in all the water lines. The water lines in the refrigerator as well as the one that supplys the refrigerator.
Feb 13, 2014 | Amana ASD2522WRW - 25 cu. ft. Side-by-Side...
How to Change ice filter in 532 sub zero my ice taste bad
The answer to your question is yes. First go to home depot or lowes and tell them you want an in line water filter for a refridgerator and you want that filter to have the brass or copper threaded connections already on the filter. While your there pick up a couple of stainless steel water lines. The fittings for the filter are going to be 1/4 inch fittings, so be sure to get the right size lines. Once your back home, pull the machine away from the wall, unplug it, jsut for safety, and turn the water off. The next thing you want to do is disconnect the old water line from the wall and from the water valve on the fridge. Before you hook up the filter make sure you note the water flow direction that should be on the side tellling you which way it should pass throught the filter. Hook up the line that will go from the wall to the filter but don't connect the valve yet. Once you got it connected to the wall get a bucket and place the line that goes to the valve in it and turn the water on. This way the filter is flushed before you hook it up to speed up the process of getting that bad water out. Ok, flush a few gallons, then hook the line to the valve, plug in the machine and your done. Allow a few cycles of ice to pass before you notice the difference. Good luck
Jun 16, 2012 | Refrigerators
Ice Smell/Taste funny
Apr 27, 2012 | GE GTH21SCXSS Stainless Steel (21 cu ft)...
We have an Electrolux S/S side by side w/Ice&water though the freezer door. The water flow through the door has been inoperative for several months but the ice maker continued to work fine. Water...
check and see if there is a built in filter pack inside the back of the fridge or it could possibly be that one of the lines has froze internally and or the open close valve at the water inlet inside has worn out
Jan 18, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
No hot water during wash
Hi..
If your washer have no hot water during wash, you need to check this:
  • Check that the water supply valves are turned on
  • Inspect the water supply hoses for kinks
  • Check the filter screen
  • Test the water level switch
  • Test the water temperature switch
  • Test the timer control
  • Test the water inlet valve
Hope it may helpful
Regards
PCmania
Jul 13, 2009 | Electrolux 23 in. ESL6114 Built-in...
Ice maker leak
sounds like you have a bad water valve,if the ice maker is disconnected and water is still filling the ice maker cup the valve is bad
Aug 19, 2017 | Electrolux Frigidaire Professional Series...
Water keeps running
Hi
Sounds like the inlet valve has failed. You need to replace the part that the inlet hose is attached to
Feb 16, 2009 | Electrolux 24 in. EDW5505EPS Stainless...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Dishwasher leaves taste on glasses
hi there sounds like your rince aid level is set to high, the adjustment for this is located under the rince aid filler cap, try setting to position 2
Dec 13, 2007 | Electrolux 23 in. ESI6104 Built-in...
I have a kenmore side by side with water an ice out the door
If you do not find the filter located in the front grill/toe plate below your freezer door or if you do not find it hanging in the top of the refrigerator section then you do not have a filter on your model. You may add an inline filter between the water supply valve of your house and the water connection on the back of your refrigerator. Since you posted it is an older model I bet you do not have a built in filter.
Nov 21, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
289 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
