Question about Westinghouse Televison & Video
I have sound but no picture, it has power as it lights up but no picture or input indicators at all.
  • Steve Johnson Feb 07, 2009
    Thank you, I waxs hoping for a "just hit the reset button hidden ......". I will get it in to a service department. Thank you very much.
  • 679 Answers
You probably won't be able to do anything to repair the unit yourself. What you can do is call around to some local shops and describe the problem and see what kind of repair costs you might incur having it repaired.
Thanks for using FixYa.
Posted on Feb 07, 2009
    Master:
  • 848 Answers
Hi
This may be the backlights and or the backlights power supply is in failure, or the drive board is not working properly.
  • gopinath pasupathy Feb 07, 2009
    Thanks for using fixya and accepting my solution .....
    Brigadier General:
  • 3,614 Answers
may i know exactly the tv model that you have?
try to check all connections on the tv
  • micromaster
    micromaster Feb 07, 2009
    it is possible that it has a loose connection somewhere.
  • micromaster
    Also check the display settings and television settings by using your
    remote. If these do not work, try getting your television checked by a
    repairman as maybe he test and inspect the tv set
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
No sound and no picture
The green indicator merely lets you know that power is getting to your TV. The absence of picture and sound could be due to power supply failure
May 18, 2013 | LG Televison & Video
I have a toshiba 43ax60 has sound no picture and the power light stays on when powered
you need to explore menue for tv options and select the proper input as well as other options.
Sep 17, 2012 | Toshiba 43AX60 43" Rear Projection...
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Will power on but no sound or picture
is there an indicator of power? LED light?
if there is a indicator that changes when input signal is insert, then the problem maybe on the LCD lamp sometimes this lamp are busted. if the indicator does not change maybe the problem is in the motherboard
Jul 20, 2011 | Westinghouse LCM-22w2 Television
No picture have sound will power on/off
Hi! the trouble you have mentioned indicates that your lcd back light is not functioning. i think the inverter circuit is in trouble or malfunctioning. usually you could re solder it or replace it with a new. the inverter circuit is the one responsible in turning your back light on.
Sep 19, 2009 | Vizio GV47LF Television
LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
Well dont keep it on!
By running it after it shutdown and it finally did its last pop that added another $XX to the parts bill.
The control boards (2) have now failed There are burned Capacitors ( pop!) and possibly even a few transistors burned out. This is not a DIY it is a Tech job as once changed these boards require additional tuning of the convergence factor.
Aug 31, 2009 | LG 47LC7DF 47 in. LCD HDTV
Vizio vx42l hdtv back light
If backlight went out then sound should still work. Are there any indicator lights to show power is coming on anymore? Try unplugging for 30 seconds, hit power button a few times, then plug back in and try to turn on. This drains any capacitors of power to attempt to reset (basically clearing the TV's throat).
Can also try something on a different input. If current input is composite, S-video, or component, try using DVI or HDMI connection as this uses a different board in the TV. If that fixes it, then at least you can try to replace one board instead of entire tv. :)
Apr 06, 2009 | Vizio VX42L 42 in. LCD TV
Plasma screen
supply problem. check the power supply of the controlling unit. not stable.
Jan 14, 2008 | Gateway FPD2275W LCD Monitor
Televison & Video Logo
Top Westinghouse Televison & Video Experts
Dave Naylor
Dave Naylor
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
