Question about Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204B random blank screen
The troublesome monitor is 1/2 of dual monitor setup. Randomly the (left) monitor abruptly goes blank. Cycle power w/ front panel button restores monitor function immediately, but only for another random interval (2 - 5 minutes, sometimes longer), then screen blanks again. Both inputs (VGA - digital) & computer video channels yield same results (it's not cables or VGA card). Time interval between blanking seems totally random. Other (right) monitor exhibits NONE of these symptoms with either computer output.
  • 1 more comment
  • Anonymous Mar 08, 2009
    I do have the same problem but I cannot solve the problem as well. shoot!!
  • Anonymous Mar 21, 2009
    djonce, I'm getting a 404 Not Found on your PDF. If you still have it, that would be very helpfull... thanks.
  • Will Waterman
    Will Waterman Mar 22, 2009
    I never had any flicker problems. Mine appears to have been more of a digital fault and replacing the digital control board inside the monitor seems to have solved this problem. I found one on ebay for about $40 and that seems to have taken care of the issue.
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Posted on Mar 12, 2009
  • djonce Mar 22, 2009
    .pdf link fixed. Sorry for inconvenience.
My LCD monitor (Fujitsu LL3200T) randomly goes blank very often while I'm using it, randomly going on and off. This only started this morning. I have been unable to isolate the problem - however it is...
You may have failing DC filter caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 30, 2010 | Computers & Internet
SyncMaster 204B - when pc goes into blank screen mode (normal) the monitor does go black (normal). But when waking up PC the monitor just start flashing the screen extremely fast, progressing slower and...
Yes, The repair is simple, it requires changing out 5 capacitors. We have a full repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-204b-lcd-monitor-repair/ We also have a parts kit available for $12 shipped.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Mar 03, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
My SyncMaster 204B Monitor just stopped working. It worked fine this morning before I left for work, but when I arrived home, it wouldn't power up. I've been Duel Screening for about 2 yrs with no problems...
Replace the screen with a known working one. If it shows display then it is the screen which is broken, if not, then it could be the port on which it is connected.
Feb 25, 2010 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 204b my screen flickers and is dim on wakeup
Your backlight power supply is about to die. Check out our web page at: www.ccl-la.com/badcaps.htm We have a full repair guide and parts list to do the repair.
Buddy
Corporate Computer
www.ccl-la.com
Sep 27, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung SyncMaster 204B The blue power button is on but the screen is black. When I turn it off and back on it shows the screen for a second then goes black. Can you please help me. Thanks
Got the same problem, happened yesterday for me, Did some research and it looks like its bad capacitors in the back, check out this page for more information... i'm taking mine to an electrician to fix today... luckily he's related and should be able to fix it on the cheap...
http://pavel.kirkovsky.com/blog/2009/03/samsung-syncmaster-204b-repair/
Apr 02, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Blank screen
if this goes blank randomly, it could be that there's something wrong with the monitor or its starting to die on you. if there's a factory reset button on the monitor, you can try doing it and if that is still not going to resolve the problem then just get it replaced if its still under warranty and if not then get another one.
Oct 07, 2008 | X2Gen MG19MY 19" LCD Monitor
Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of http://www.datapro.net/techinfo/dvi_info.html.
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Feb 13, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung monitor randomly flashes black
> brand-new out-of-the-box
Presumably, it has a "warranty".
So, take it back to where you bought it, and demonstrate the problem to them, and make them repair/replace it, under warranty.
Sep 21, 2007 | Samsung SyncMaster 214T Monitor
Color changes and flickers
To prove which Card or monitor are you in the position of either A- getting hold of another monitor or B Another computer connected to troublesome monitor Either way will establish which is the troublesome one. Then come back
May 08, 2007 | HP A4033A 20 in. CRT Monitor
Samsung SyncMaster 204B 20.1" LCD Monitor Logo
574 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
