Question about Maytag Washing Machines
Maytag A7800 washer does not agitate
It also does not spin out the water. It appears to pump out most of the water, but the clothes are still quite wet.
  • 3 more comments
  • periwinkle Feb 07, 2009
    I opened the lid and held back the button to observe if it was agitating. It was not. I held the hooked pipe where the water goes into sewage system, and some water WAS coming out--in trickles. There is no water showing in the tub at the end of the cycle, but the clothes are very wet. This machine belonged to my grandmother, and it is quite old. However, if it is just a belt and washers, I can probably get a family member to help me with that. Do you know a site that offers prices and/or manuals in USA at a decent price? Lastly, lovely to hear from UK as I lived there for almost four years as a child. Thanks.
  • periwinkle Feb 08, 2009
    I can hear the humm of the motor, so I don't think that will be a problem. My son will be able to check it out soon. As you say, you will be able to see the problem immediately if the belt has slipped or broken. I am glad of the suggestion of brushes to make it last longer. That is a good idea. I had seen that the UK was under some severe weather. Under zero is never, ever a good thing. Stay warm as possible. Thanks again for your help.
  • silver top May 11, 2010
    hi thank you for update glad to hear someone you know can check the suggestions i made in prev reply ? it sounds very much like either belt has come off/snapped for the drum not working? if checked out it will be obvious to see? i assume when machine was on it did the full wash cycle but at end you hear pump working ?pumping out water ? so cycle has run ok ? if machine is running ? can you hear motor at any cycle ? if not then motor may not be operating again your handy man/woman? can check this if belt is ok? then if motor is suspect and considering age of machine? best remove motor //just like auto alternator same securing method ? i am afraid i am unable to help with source of where you can obtain brushes in usa ? but am sure there will be ? think positive? they built these machines to last in the days your gran bought it not like these days so just a thought for you ? if machine was ok prior to this fault and washed ok to satisfaction ? then i am sure new belt and motor brushes if needed? will give many more years of service ? i hope you get machine repaired and if you req further info you can e mail glad to help ? weather update in northwest uk is chaotic and icy/snow and roads gridlocked throughout with minus 5deg tonight again with worse snow to come ???? best wishes from the freezing uk !
    hi from uk from the symptoms you describe ie no agitation of drum and not spinning? this is more than likely the drive belt has snapped ? or come off to to loose /not tensioned ? to fix /fit new belt and retension much the same as auto alternator belt ? however if belt ok? it may well be the actual motor? may i suggest that if machine is oldish ? you may just need to replace the motor brushes they wear down over time and are simple d i y to replace cost in uk £5--£6 for new set x 2brushes ?
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: washer doesn,t spin
Looks like chat support session must have timed out. The answer to your last question was, yes, pres. analog switch with a red, a white, and a blue wire to it.
Posted on Oct 27, 2008
  • 77 Answers
SOURCE: Maytag clothes washer, with pump and belt replaced in Nov. 2007, clothes were too wet after spin cycle
The start of the spin cycle is dependent on the pump pumpin out water and the later level switch sensing that the water level is low enough. The water level switch has (usually) a clear tube connected to it and is found in the control panel. You will want to check continuity at different times. First you will fill the tub to the highest water level. Then unplug the machine. By screwing in the screw on the water level switch. Scew it all the way in. then you will check continutity. there should be no cont. between green and brown. and there should be cont between green and black or yellowblack. Do this continuity test with the wires off the switch. Once this test is complete, reattach the wires and plug in the machine and set the timer on spin or drain. When the tub is pumped dry, stop the spin cycle and unplug the washer and do the continuity test again. This time you should have continutiy from green to brown. and no continuity from green to black or yellowblack. Now when i mention the colors that means the placement where those wires were. Make note before you remove them so that you can get them back to place. If you do not get these readings, the water level switch is bad, or there is a leak in the air pressure tube leading to it. At that point I would replace the entire switch and tube. I wish you the best of luck.
Posted on Apr 21, 2009
  • 234 Answers
SOURCE: washer will not spin properly- will agitate, like
Again I shooting in the dark because you have not given any details of model, but typical maytag has a belt or two under neat; one for the pump and one for the drive mechanism. If the belt for the drive is stretched or glazed and slipping, you need to replace it and possibly adjust the tension of the motor cradle. If the is not the problem or does not solve the problem, then you have the big problem of the trans drive worn and if the unit is old, you may want to buy a new machine. You can ask some repair service places the cost to replace the trans drive so you better know where you stand or you can attempt it yourself but it is not for the first timers. Good luck, Mascgivor
Posted on Oct 11, 2009
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Maytag A7800 washer wont start agitation with lid closure
you need a new lid switch assembly, which will run you about 30 - 40 bucks
Jun 05, 2012 | Maytag Washing Machines
Maytag top load replaced belts and still washer will leave water on spin cycle half full. If I play around with it I can get it to drain
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Nov 26, 2010 | Maytag PAV2300 Top Load Washer
I have a maytag washing machine model PAV2300AWW that is leaking water and only draining 1/2 of the rinse load. Could this be a pump motor issue?
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 16, 2010 | Maytag PAV2300 Top Load Washer
Maytag washer quite 100 water doesent go out during rinse cycle, so after washinging, I have to remove the water with a bucket.
Jan 01, 2010 | Maytag Washing Machines
Maytag PAV2000AWW will not drain or spin in 2 of the 3 wash cycle
It won't drain
Nov 27, 2009 | Maytag Washing Machines
Apr 21, 2009 | Washing Machines
Old model rca washer machine...will not agitate/wash the clothes,does spin.
If the washer fills up with water and you hear the motor running but the agitator doesn’t move, the agitator coupling is the most likely problem. First pump the water out by turning the timer to spin. Once the water is out, turn the washer off. Now pull up on the agitator until it comes off (it may be hard to pull off). Now that the agitator is off, you can see the agitator coupling, reach down and try to turn the coupling. If the coupling turns freely, it is striped out and needs to be replaced.
Sep 29, 2008 | Washing Machines
Won't empty water slow spin in spin cycle
if this helps please vote a fix ya
Jul 15, 2008 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
