Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
UF-885 goes dead when I edit one-touch a/o abbreviated-dialing
I can change the phone number of an item in one-touch or abbreviated-dialing, but then the screen asks me to change/verify the station name. When I do and hit 'set', all of the buttons go dead. Screen is still legible, but I need to unplug electricity to get back to useable status. The attempted edit is not saved.
  • rspoelhof Feb 08, 2009
    Thanks. That did it. I had tried that before, but missed the '*' after the monitor key.
    Genius:
  • 2,120 Answers
You need to do a GLOBAL RESET. the machine will reset to factory defaults clearing ALL settings..
Function
7
press monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for the machine to initialize.
Posted on Feb 07, 2009
  • Leroy Elliott
    Leroy Elliott Feb 08, 2009
    I forget the * sometimes too,
    Thanx fot the FixYa!
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634 on the Panafax Uf-885
No dial tone detected, make sure you are plugged into the LINE port.
Sep 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
UF-885 Panafax
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
press SET or START
press 2
wait for the machine to reboot.
Dec 30, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Cannot change or erase one-touch/abbreviated dailing numbers
press function - 7- 2 - start- 1 press the one touch you want to program. - enter the number- start- name start- should go back to the machine asking to press another one touch then hit stop..
Dec 18, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Cannot send fax until I activate the Memory button, want to send "Direct"
Hi rlandriani,
There should be a setting under user paramaters in the menu section that will allow you to change the default "memory on" setting to "off".
The user parameters set on the menu currently can also be printed for you to go through at your leisure so that you can customise the machine to your own personal prefferences.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
If there are two RJ-11 jacks on the fax machine you need to make sure that the line from the wall is plugged into the LINE jack not the TEL jack. If that is not it let me know and I will provide you some troubleshooting instructions from the factory service manual.
Sep 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Answer a distinctive ring?
No, distinctive ring is not available on this machine.
May 24, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
One Touch Dialing numbers won't permanently save to FAX machine
If you followed the procedure F 7, 2 set, 1 for speed dial, enter your free speed dial space, enter your fax #, set, enter the name, set.(continue to next free speed dial key or stop) If this doesn't work then you may have a bad battery on the main board that saves the data if the power goes off.
Feb 04, 2008 | Panasonic Panafax UF-560 Plain Paper Laser...
Takes too long to send a fax, errors out
please tell whether you get to hear the ring tone and further to that fax tone on the other side or not?? then i can suggest ... happy faxing omnipresent
Aug 10, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
100 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
